Chruk has a another point that a small sprocket may put more strain on studs ( kind of a mind screw to think about it) So based on everything Im hearing in the latest posts:
A Your clear coat might all fall off if parked outside in the weather. Can be gathered up and used as sandwich wrap.LOL
B Get a set of extra sprocket studs before you need them! Beause,... as soon as your bike breaks the weather will get super nice. Murphys Law
C Rethink getting too small of a sprocket. :confused1:
D Store your bike in a climate and humidity controled darkroom immediatly to prevent all of the above...:hellfire:
chruk bashre
some one has a wife making and selling seat covers for the df-rtb.
please help. i don't feel like going across all these pages again. my notes don't help a bit. time to learn how to take notes. i never needed a computer on the side to take notes when i used a pencil.
so if i could be hooked up with the email or whatever i need to contact, i think the name gemma, comes to mind,,, i will order right away.
thank you so much
:confused1:chruk
that would be skullworkz wife. she does some pretty nice work from what ive seen. check out page 272. Ghost had one made along with a tank wrap. Nice:mwink:
Its Skulworkz wife/ she does nice work. I am going to have them do a new cover for me soon too.:thumbsup:
chruk bashre
ha...thats funny
Oh I forgot one/ Find a mini screwdriver made in the land of OZ for adjusting carb/ just dont loose it when you do.
chruk bashre
CRELOW- just a troubleshoot thought. first make sure that plate on the side of the engine is plugged REAL good from where you did your (SAIS) mod. i don't know what you are plugging that hose with that is still dangling there. you put that plate back on upside down so make sure it doesn't leak. i would recommend turning that back around just to see. did it run the same before you removed the emission junk?
The way I plugged it was I grabbed a dell computer. Then grabbed a pair
Of metal sheers placed the tube on the metal to create a template. Sharpie then cut and and drill. Ground down any unsafe edges. Put the plate with the old tube upside down so it won't collect water. And high temp RTV. I think that's what is call and loctite.
chruk bashre
bowtiewagon-amazing! almost 9000mi. how are YOU holding up.
about a sportster i used to run, one day on a take off, the rear sprocket just spun around. but i did have the sprockets all juiced up, 1st was more like 2nd, and 4th never ended. that is why i was curious to the size sprocket you use. if take off is not instant, meaning a lot of throttle and clutching to get going, that would be puting too much unmanageable pressure on the sprocket bolts. now i dont know how many teeth you have on the back but i do know that the second time i had to fix my sporty i changed the gearing to please the drive-train. maybe you have to go back up a tooth or 2. ???
For an old guy(yeah i know 48 is not old,but feels like it sometimes) I am holding up fine with the ride.Sometimes I get that weedeater feeling in my hands on longer rides, but overall...just great.
I have a 35 tooth on the rear. I try to shift smooth on it coming off the lights, but sometimes I jerk her. Guess its just part of the ride to go through stuff like this.
Thanks guys for hanging in there with me. I think I finally got it.
From what I remember after taking the carb apart. Found nothing wrong there.
Turned the air mixture screw 2half turns. After it warmed up I turned it a little more.
Then the idle screw. Wiggled the wires coming from the motor and that was it.
I think my problem was I kept setting the idle way too low causing that hiccup. Ill take a video tomorrow morning if I have time to show the puff of gas if it happens. But for now I think Kareem ing the tank will be my cheaper option to keeping the bike before investing so much.
Hello guys thanks for the info. The more I look at the pictures.. the more i wish I bought the older triumph style DF instead of the newer Harley looking one. Oh well.
I already ordered a 35 rear sprocket.
Looks like all i need to do now when I get the bike:
-Drill a few holes in the battery vox
-Change the oil with a nice synthetic
-Replace the spark plug with an NGK (what type and what gap? Im sure its already been posted a million times but ive have not read too far in yet)
- Tune the carb
Anything else I need to know?
