some more photos
Attachment 12949
Attachment 12950
Attachment 12951
If you are interested, I will describe all the little damage that we had in Russia
some more photos
Attachment 12949
Attachment 12950
Attachment 12951
Sergio how was the bike being used before this engine damage occurred?
I'd love to know what happened.
Don't ask me how I know but my bet is Hydrolock from one of the root causes in mentioned below.:deal:
Causes of Hydrolock
- Outside water can enter the engine through the air intake if the vehicle is driven through a flood; vehicles designed with low-mounted air intakes can draw in water from a bow-wave caused by driving through relatively shallow standing water. Engine coolant can enter the cylinders when a head gasket blows. A failure in the carburetor or injector mechanisms can introduce liquid gasoline where only a vapor-air mixture should be.
What Gets Damaged
- Although an engine that hydrolocks at idle may simply stop, catastrophic engine failure is likely if an engine hydrolocks while running at speed. The most common result of hydrolock at speed is that the piston rods are deformed; they bend and fold between the piston at their top, which cannot travel upward any farther, and the crankshaft at their base, which continues to travel upward. Absorbing the force of the sudden stop may crack the block, crack the crankcase, destroy the head and shatter the bearings.
guys, it is not known what happened, the engine was sent to the warranty service, when I know what happened then immediately write to you
I think everyone is interested on the circumstances this happened in.
The result is pretty clear, and the engine is toast, but what led to this?
E.
just bought the Bike last month for USD 14.5k .
Here they sell under Benelli BN600 a.k.a Huricane .
Hope can share info with the bike owners here.
Hello, recognized engine damage covered by warranty, will change the engine on a motorcycle, but because of what happened no one knows.
Currently on motorcycles sold in Russia often occur following damage: broken temperature sensor, fuel level, begins to flow front fork, crack the glass dashboard and stays on the sensor that is faulty injector. The most high mileage on a motorcycle sold in this country of 18,000 kilometers
Hi, guys, could someone help me with electric diagram for our bike? I'd like to install DIGI gear indicator, but can't find the right wares. (speedo pulse, taho pulse and so on) Maybe someone already knows description of dashboard socket?
Thanks in advance:)
