Nice work bobthebobber. I was thinking about gloss black but i think i like yours better.:clap:
OMG I still have the photo I took. I have a habbit of saving photos. Good or bad sometimes its good to keep records.
Glad you got it fixed. I would still order a third party replacement though. That way you have a spare. I keep the new one in my tool bag.
I also did the extra nut thing but the reverse threaded one is impossible to find locally.
To Crelow and others: I suggest you order a third party rod now as I guarantee the stock rod WILL break. It's just a matter of time. Very little money for having piece of mind in your toolbag. Mine was only about $25 or so per DanDaMan's link. That's where I got mine.
6 months or 600 miles. I'm glad I changed mine as it was really sludgey on the magnetic oil plug. Also, it had the silver sheen to it. It didn't have anything noticeable in the filter upon inspection. I have also noticed that the rod that you guys have that are breaking is a different color than mine. Yours seem to be a goldish color and mine is more of a silver color. I wonder if they are from different stock? I'll snap a pic of it when I get a minute.
[QUOTE=DanDaMan;55661]yes i use standard car oil , Ive never even changed it , Ive drained and strained it , but still using same oil as I put in it that 1st day some 5k mikes ago
the BULBS on this bike are terrible , everything that runs continuosly , tail running light / headlights , break every time you hit a good bump
I put in a car sealed beam headlamp , and a 4" strip of LED's from autoparts store into rear brake for running lights , I still use standard bulb for normal brake light
dont fool yourself thinking changing bulbs in tail lamp will help its a hard tail , I went thru about 50 bulbs , all brakelight still working but busted running light be4 I wised up
Tip on Tail lite: I found a 1157 tail lite bulb at Autozone that is a LED/ Just plugged right in to
the socket no mods needed and it should last forever as LEDs are not affected by vibration. Cost was about 7 bucks/ I then added a small plastic mirror in the Tail lite housing at a 45 degree angle to throw off more lite as the LEDs are directional and the bulb is sideways in the housing. This makes the light shoot out the back where it is needed.
I am doing a flat black on mine. I have the fenders done, headlight acces panels going to powerwash the frame before I do that. it has a bit of a shine to it not glossy whick I love. I can not believe this plasti-coat stuff it is great. I ordered some drag bars, new smaller mirrors, bullet back turn light, a Model A brake light and I ordered a tan solo seat. I want to post before and after pics after it is done which will be soon. I wanted to go with baby apes but the cost of longer wiring for all the cables did not want to do that yet.
:confused1:
Hello All,
Just want to throw out a quick question. Anyone know of an inexpensive tachometer (dial-gauge style, not LCD) for single-cylinder engines with DIS? The tach that Cleveland Cyclewerks has on their "Misfit" would be ideal but I doubt they sell them piecemeal. I've heard that you can convert a Sunpro gauge to work but I can't find much info on how.
be careful with the plastidip. The reason i didnt use it.. if you get a little scratch and wind gets under it, it will all just peel off like latex. Looks so nice though
