They probably spot weld those clips when they manufacture the fender, so yeah I'd tell them I want a new fender too. The fender supports are all bolted. I would imagine you can loosen all the bolts and position the fender so that you have the proper clearance and then tighten things back down. Something that should have been done when they built it.
4 Attachment(s)
i was told NOT to do this
Attachment 11317
here is what you should have to put on a new sprocket. the 2 top rings are original parts, the bottom is a shim i made. whatever you buy determines the thickness of the shim you need. i bought a shim washer, made the middle bigger and slotted the outside for the nuts with a dremel.
Attachment 11318
Attachment 11319
Attachment 11320
when you take off the wheel, you only need to lift the entire sprocket configuration out of the hub. you do not have to loosen the nuts first to
take it off. the whole thing will slide right out. so never mind the new
hub first. park it first and rip it down. if you can get a spacer in there,
that may be all you need. but do it now.! good luck. dont give up.
just do what the other guy who sold it to you didnt do.
congrats on df250rtb ownership. the bike is the balls.
