GonzoX
Good to hear Chruk.
Now i feel the need to inject a noob question.
Got a leak on my DF and it appears to be oil. The strange part is that it is coming from a rubber hose out of the bottom of my carb. my question is what the he** is this and what is its purpose? The hose appears to be a drain hose of some kind and it is flared on the end.
Any ideas?
Attachment 11482
gas , bottom of u carb is a fuel drain screw , when loose it drains gas out the carb via that hose
its purpose is to drain fuel from the carb (when gas tanks also turned off) so when performing maintenance your not sloshing around a full carberator
tighten the screw
chruk bashre
the tire and fender line up, right? this shows that the tire would kinda lean to the left. or the right side of the fender would be too high. how does that stuff look? does it seem true? if it is, i say let it be. but have a cycle expert take a peek. any shop with would stop what they are doing to take a look at that. good luck and let me know what they say.
Maybe the Allen bolts came loose on the triple tree.
DanDaMan
tighten the screw
Thanks Dan,
Will look at it tomorrow. Got home at 1am and Im too damn tired to mess with it now. Good to hear it's a simple fix though.
GonzoX
Thanks Dan,
dont be so glad , leaving it open for to long can "varnish" the inside u carb , but a small treatment of "stabile" can save the day
sorry i forgot to take a picture of when i was done with the 'wires for the headlight under the tank" repair. after the repair the headlight gets brighter when motor is revved. the brake lever does not interfere with the brightness of the light. here is a picture with directions of what i did. the dark green is a ground. if i take the tank off,(never)again, i will get a good pic of it.
Attachment 11497
chruk bashre
Attachment 11497
Can you post a few more pictures i can barely see what's going on. If you have a point and shoot camera. Push the button that has a flower on it. This allows the Macro feature to be enabled allowing for closer shots.
this is the best i can do. i made a giant close up. let me know if you can see it gooderer.
Attachment 11498
here i made another one for ya. let me know how it ???
Attachment 11499
chruk bashre
So green to green and blue with stripe to blue with stripe?
On my bike I have 3 wires that are blue with white stripe. Attachment 11501
