Parts are being bought through these peeps now........................
Tab Bike Imports.
Tel: 01246 251798
If they dont have it in stock they order it in. You dont pay until they have it and the prices are keen as well.
Tab Bike Imports.
Tel: 01246 251798
i have a tmec 200 anyone know what rear sprocket i can get for it to make it top out higher? it has a 56 and to me that seems to be a little crazy.
Right then, my son has managed to wreak this little buzzbox. So I am taking over the ownership and it will be my project over the coming winter nights.
First off I need new rear wheel bearings ( I am guessing there is two). If I manage to replace them via Central Bearings in Redditch, I will let you
know, I will not be using OEM as these must be shit to wear out after only 700 mile.
I also need a new Drive Chain or a Chain and Sprocket set as the original one snapped another example of poor metal and not regular oiling.
The small metal chain guard at the rear of the engine was smashed as a result of the chain snapping, so I am in need of a breakers to get a
replacement secondhand part along with some other little bits and pieces .............
Aha an update ................................
Central Bearings in Redditch indeed done the rear wheel bearings FAG 6003zz and they are fitted.
Now adding a piece of rubber to cover the monoshock.
Done a bit of respraying using Plasticoat Matt Black, not an exact match but looks better.
Found a Speedo cable, well I say found I had an expert make me one. Cost £15.00.
Rerouted the speedo cable through a home made metal carrier.
Just need to dremmel out the chain cover so it fits with the electronic timing cables and source a Chain and the
beasty lives again............................... :)
Dremmel worked a treat and respayed the front sproket cover in satin black ................
Final Drive Chain proving to be a pain. Can't seem to locate one ....... Hmmm
Anyone on here know the size, pitch etc .........?
Or has got a secondhand one with some life left in it ........?
http://www.rbracing-rsr.com/chainlength.html
Just found the above ..........................
So if it is a 428 chain it would be .500 / 17 / 56 / 24 = 133/134 Link.
Over to the experts .................
Turns out an Email sent to Tmec themselves produced this reply ............................
发件人: Vic
发送时间: 2013-01-21 00:59:18
收件人: tmec@vip.163.com
抄送:
主题: Tmec 125cc Enduro 2011 Model
Hello
Please tell me the chain pitch and length for your
TMec 125 Enduro 2011 Model.
Thank You
Victor
DEAR VIC
THANK YOU FOR YOUR EMAIL. OUR CHAN FOR TMEC125-1 IS 428H-132.
BEST REGARDS
ELLEN
Which is very helpful indeed ....................
