Re: Motorcycle Parts names in Mandarin
What would you like me to do MJH? You do not communicate well, to my comprehension anyway but thanks for responding.
Some things you could suggest are harmful or difficult, so please keep it relevant to the posts? I would prefer some public (or private, your choice) resolution rather than just deletion.
What's a)kerosine and b)mineral spirits also known as paint thinner(commercial name) in Chinese?
Not really a motorcycle part, but still related somewhat. Clean your chain! But since the accident I'm not riding as much, just on the bicycle nowadays. Always two wheels of course!
I need to clean the chain on my bicycle, and paint thinner seems to be better than WD40 for the job. Also kerosine seems to be another choice for the job.
slabo
kerosene 煤油 | paint thinner 天拿水/ 香蕉水 | Diesel 柴油 are also very good for chain cleaning.
humanbeing
kerosene 煤油 | paint thinner 天拿水/ 香蕉水 | Diesel 柴油 are also very good for cleaning chain
Why is gasoline not good? Other than it's dangerous, catches fire easier than diesel or kerosine.
You need to be careful of the O'rings; many strippers, thinners and gasoline may perish them. Lots of people use WD 40 and say it is fine but it is not recommended because it can get in and wash out internal lube behind the 0'rings. Whether these chemicals do actually hurt the rubber or not or whether they get in behind the O'rings and affect the manufacturer's lube set up is another matter - but I prefer safe to sorry as I do not want a chain sticking at 100 kph.
Kerosene is said to be OK by the manufacturers and in the 'olden days' we used it as it also got into all the fine joints and gaps and acted as a lube itself - with O'ring chains the gaps are too fine for it to penetrate and wash out the existing 'lube but it cleans well and doesn't affect the o'rings.
So, for all fashionista iphone, nerdy android and all the other users: this is the parts and terms list, mainland usage according to humanbeing and with pinyin. Going through this list I actually learned a lot of english words I had never heard of before or just did not know the meaning of.
Anyway, please all check for errors and typos and please add more if you know!
Parts
adapter 转接座 zhuan jie zuo
air box 空气滤盒 kong qi lu i he
air filter 空气滤 kong qi lu
alternator 磁电机 xi dian jī
aluminum 铝 lü
aluminum rim 铝圈 lu kuang
axle 车轴 che chou
battery 电瓶dian ping (motorcycle/car) 电池dian chi (electronics)
bearing 轴承yhou cheng
bike stand 大撑 (standing mount)
bolt 罗栓 luo shuan (refers to the bolts on the wheel)
bracket 卡箍 ka gu
brake 刹车/ 制动sha che/zhi dong
brake caliper 卡钳/ 下泵 ka qian/xia beng
brake light 煞车灯 / 刹车灯 sha che deng
brake line 煞车油管 sha che you guan
brake pads 煞车片 sha che pian
brake rotor 煞车碟盘 sha che die pan
bulb 灯泡 deng pao
cam shaft 凸轮轴 tu lun zhou Nockenwelle
carburetor 化油器 hua you qi
carburetor jets 油咀/ 三角针 you ju/san jiao zhen
chain 链条 lian tiao
choke 阻风门 zu feng men
clutch 离合器 li he qi
clutch cable 离合器线 li he qi xian
clutch pads 离合器片 li he qi pian
coil 点火线圈 dian huo xian juan Zündspule
connecting rod 连杆 lian gan Pleuelstange
coolant 冷却液 leng que ye
crank shaft 曲轴 qu zhou Kurbelwelle
cylinder 汽缸 qi gang
drum brakes 鼓煞 gu sha (鼓式煞车) gu shi sha che
disk 碟盘 die pan
electrical tape 电器胶带dian qi jiao dai
engine case 发动机箱体 fa dong ji xiang ti
engine head 汽缸头 qi gang tou
exhaust pipe 排气管 pai qi guan
fairings 外壳 wai ke
front fork 前叉 qian cha
fiberglass玻纤/ 玻璃钢bo gan / bo li gang
filter 过滤器 gùo lü qi
foot pegs 脚 踏 jiao ta
frame 车架 che jia
fuel gauge 油表 you biao
fuel injection 燃油喷射 rang you pen she (EFI电喷 dian pen)
fuse 保险丝 bao xian si
gas cap 油箱盖 you xiang gai
gas line 油管 you guan
gas tank 油箱 you xiang
gasket 垫片 dian pian
gauge 表 biao
gear 档 dang
gear lever变档杆 bian dang gan
generator 发电机 fa dian ji
grease 黄油 huang you
handle bars方向把fang xiang ba
handle grips 把套 ba tao
head light头灯 tou deng
horn 喇叭 la ba
horn button 喇叭按钮 la ba an niu
hose软管ruan guan
ignition点火dian huo
ignition button点火 按钮 dian huo an niu
intake进气管jin qi guan
jet 喷咀 pen ju
key 钥匙 yao shi
kickstand边撑bian cheng
kickstarter启动杆/ 打火棍 qi dong gan / da huo gun
levers牛角niu jiao
license plate 车牌 che pai
linkage 打档杆 da dang gan
lock 锁 suo
magnesium rim 镁轮圈 mei lun juan
master cylinder上泵/总泵 shang beng/zong beng
metal 金属 jin shu
mirror 後视镜 hou shi jing
muffler消声器xiao sheng qi
neutral light 空档灯 kong dang deng
nut 螺丝帽 luo si mao
odometer 里程表 li cheng biao
oil 机油 ji you
oil additive机油添加剂 ji you tian jia ji
oil filter 油滤you lü
oil gauge 机油表 ji you biao
oil pan 油底壳 you di qiao
oil pump 机油泵 ji you beng
oil seal 油封 you feng
oil: blended synthetic -- 半合成机油 ban he cheng ji you
oil: petroleum-based -- 矿物油 kuang wu you
oil: synthetic 合成机油 he cheng ji you
pet cock 油箱开关 you xiang kai guan
piston 活塞 huo sai
piston rings 活塞环 huo sai huan
plastic 塑胶 su jiao
pulley皮带轮pi dai lun
pulley belt 传动皮带 chuan dong pi dai
pully rollers 普力珠 /离合珠pu li zhu / li he zhu
pump泵 beng
radiator 水箱 shui xiang
radiator cap 水箱盖 shui xiang gai
reservoir 副水箱fu shui xiang
rim 轮圈 lun juan
RPM gauge 转速表 zhuan su biao
rubber 橡胶 xiang jiao
seal 油封 you feng
seat 坐垫 zuo dian
shell/fairing 外壳 wai ke
shocks减震 jian zhen
slicks无纹热熔胎 wu wen re rong tai
spark plug火花塞/ 火咀 huo hua sai / huo ju
spark plug cap高压帽/ 火咀帽 gao ya mao / huo ju mao
spark plug wire点火线 huo xing sai dao xian
speedometer 速度表 su du biao
spoke wheels輻條轮圈 fu tiao lun juan
spring 弹簧 tan huang
sprocket链轮/ 齿盘lian lun / chi pan
starter motor 起动马达 qi dong ma da
stator定子 ding zi
steering damper 防甩头 /扭力杆fang shuai tou / niu li gan
swing arm 摇臂 yao bi
tail light 尾灯 wei deng
tail pipe (排气) 尾段 (pai qi) wei duan 尾管 wei guan
temperature gauge 温度表 wen du biao
thermostat节温器jie wen qi
throttle 油门 you men
throttle cable油门线you men xian
throttle controller 油门座 you men zuo
tire 轮胎 lun tai
transmission gear 变速齿轮 bian su chi lun
transmission lube 传动油 chuan dong you
transmission 变速箱 bian su xiang
triple tree (上/下) 联板,三星 (shang/xia) lian ban / san xing
turbo 涡轮 wo lun
turn signal转向灯 zhuan xiang deng
valve 汽门 qi men
valve stem 轮胎气嘴 lun tai qi zui
water pump 水泵 shui beng
washer 垫圈 dian juan, 垫片 dian pian
windscreen 挡风版 dang feng ban
windscreen(glass) 挡风玻璃 dang feng bo li
wiring harness 电线总成 dian xian zong cheng
voltage regulator整流器 zheng liu qi
zip tie札带 zha dai
Terms
1st gear 一档 yi dang
2nd gear 二档 er dang
3rd gear 叁档san dang
4th gear 四档 si dang
5th gear 五档 wu dang
6th gear 六档 liu dang
2-stroke 二冲程 er chong cheng
4-stroke 四冲程 si chong cheng
acceleration 加速 jia su
adjust 调整 tiao zheng
burnout 烧胎 shao tai
change 换 huan
change gears 换档 huan dang
check 检查 jian cha
compression 压缩 ya suo
crash (to have an accident) 事故shi gu
crash (to hit something) 撞倒 zhuang dao
crash (to fall down) 倒下dao xia
crash (to slide out) 甩倒 shuai dao
displacement 排气量 pai qi liang
downshift 退档 tui dang
drift 甩尾 shuai wei
estimate (price) 估价 gu jia
fixed 修好了 xiu hao le
horse power 马力 ma li
idle 空转 kong zhuan
inflate充气 chong qi
install 安装 an zhuang
insurance 保险 bao xian
license 驾照 jia zhao /驾证 jia zheng
leak 漏 lou
lean (body) 侧掛 ce gua
lean (motorcycle) 压车 ya che
loose 松 song
maximum speed极速 ji su
modify (stronger) 改装 gai zhuang
paint 油漆 you qi
spray paint 喷漆 pen qi
stock 原装yuan zhuang
take off 拿掉 na diao
registration 行照 xing zhao
RPM 转速 zhuan su
soft 软 ruan
stable 稳定 wen ding
start (engine) 发动 fa dong 启动 qi dong
stiff 硬 ying
tight 紧 jĭn
torque 扭力 niu li
tune up 调校tiao jiao
vehicle license行驶证 xing shi zheng
wheelie独轮/ 翘头du lun / qiao tou
Riding Gear
boots靴xue
gloves 手套 shou tao
helmet 安全帽 an quan mao/ 头盔 tou kui
knee pads 护膝hu xi
knee pucks/sliders 滑行块 hua xing kuai /磨包 mo bao
rain gear - 雨衣 yu yi
riding gear (general) 防甩衣 fang shuai yi
suit (leather) 皮衣 pi yi
Types of vehicles
Car 汽车 qi che
Big Motorcycle 大排 da pai
Motorcycle(general) 摩托车 mo tuo che
Motorcycle (e.g naked bike ... ) 骑式车 qi shi che / 男装车 nan zhuang che
Motocross 越野车 yueye che
Supermoto 滑胎车 hua tai che
Motorcycle(e.g scooter) 坐式车 zuo shi che / 女装车 nü zhuang che
Scooter 踏板车 ta ba che
Can anyone tell me what a "high pressure switch - 高压… - gaoya…" is/does?
I'll try to get the full chinese word for it later, when I pick up my bike.
Here is a challenge ...
dielectric grease
How do I say / write that in Mandarin? I need to keep those electrical gremlins at bay. A taobao link would gain bonus marks!
Wow Jape - I am damn impressed! From the land down under, no less!
Thanks!
Next challenge, can you find it priced for under 10 rmb? :lol8:
Cheers mate
