In that case I'll have a street triple......:naughty:Quote:
Originally Posted by [URL="http://www.mychinamoto.com/forums/member.php?1182-euphonius"
Attachment 7217
Displacement: 675.00 ccm (41.19 cubic inches) Engine type: In-line three, four-stroke Power: 106.00 HP (77.4 kW)) @ 11700 RPM Torque: 68.00 Nm (6.9 kgf-m or 50.2 ft.lbs) @ 9200 RPM Compression: 12.7:1 Bore x stroke: 74.0 x 74.0 mm (2.9 x 2.9 inches) Fuel system: Injection. Multipoint sequential electronic fuel injection with SAI Fuel control: DOHC Ignition: Digital-inductive type via engine management system Cooling system: Liquid Gearbox: 6-speed
Chassis, suspension, brakes and wheels Frame type: Aluminium beam twin-spar. Braced, twin-sided, cast aluminium alloy swing arm. Rake (fork angle): 24.3° Trail: 95 mm (3.8 inches) Front suspension: Kayaba 41mm upside down forks. 120mm travel Rear suspension: Kayaba monoshock with adjustable preload. 126mm rear wheel travel Front tyre dimensions: 120/70-ZR17 Rear tyre dimensions: 180/55-ZR17 Front brakes: Double disc Front brakes diameter: 308 mm (12.1 inches) Rear brakes: Single disc Rear brakes diameter: 250 mm (9.8 inches) Physical measures and capacities Weight incl. oil, gas, etc: 189.0 kg (416.7 pounds) Seat height: 800 mm (31.5 inches) If adjustable, lowest setting. Overall height: 1,060 mm (41.7 inches) Overall length: 2,000 mm (78.7 inches) Overall width: 735 mm (28.9 inches) Wheelbase: 1,410 mm (55.5 inches) Fuel capacity: 17.40 litres (4.60 gallons) Oil capacity: 3.50 litres (0.23 quarts)
I'd buy one if I could get one for around 70,000RMB.
