Re: Yingang 重庆银钢科技(集团)有限公司
YGR250R
http://i784.photobucket.com/albums/y...80734e6f0b.png
This is a air cooled single with 12kw?
Will you have this models with the DOHC water cooled 250?
I am not reluctant to talks about the naming, its another rip off of Honda.
Its Yin Gang not Yin Yang which is all about the balancing the masculine with the feminine.
I find use of logical manipulations amazing, idea stealing not so much. However Karma she is busy, but she alway catches up. The Unicorn is not legendary it would be considered a mystical creature, words do have real and actual meanings.
I like the YG250-NF and the improved model and the improved marketing, in that its improved, it still not excellent.
Good imagery is very powerful.
http://www.chinamotorworld.com/ke/at...4941_63986.jpg
Yingang is now offering a 300cc version of the NX250 DOHC 4-Valve.
They are offering it in a Dual Sport:
| EngineModel |
YG176MN |
| EngineType |
one cylinder、water-cooled、four-sroke、four-valve、EFI system |
| Displacement(ML) |
300 |
| MaxPower(kw/r/min) |
19/(8000±500r/min)(25.94hp) |
| MaxTorque(N·m/r/min) |
25/(6500±500r/min) |
| Idling Speed(r/min) |
1500±10% |
| Consumption(g/(kW·h)) |
≤354 |
| Cylinder Diameter * Stroke(mm) |
76×65 |
| Operating cubage of the cylinder(ml) |
295 |
| Compression Ratio |
10.8:1 |
| Ignition |
CDI |
| Spark Plug Model |
NGK C9EH-9 |
| Carburetor Model |
PD33J-C (135) |
| Lubricating Capacity(L) |
1.3 |
| Petrol Type |
93# |
| Clutch |
Manual、Coil Clutch |
| Starter |
Electric |
| Lubrication |
Pressure Splashing |
| Transmission |
6 speed |
| NetWeight(kg) |
35 |
| Packing Size(L×b×h) |
460×395×575 |
That's not "crazy little Ducati Monster", but a mere copy of Honda Grom, a.k.a. Honda MSX125!
"Mere copy" of "Grom" can be, for example, this (allegedly) "Jiajue Motrac".
Attachment 16780
The one MJH posted is, without any doubts, inspired by Ducati. And it is bit... unsightly.
Wow, forget about Yingang and Grom! Zorge's back :naughty::riding:
Yingang maybe attempting to resurrect an old Honda for Romet.
http://i784.photobucket.com/albums/y...5131150501.jpg
Engine |
| Engine Model |
| Engine Type |
| MaxPower(kW/(r/min)) |
| MaxTorque(N·m/(r/min)) |
| Ignition |
| Startsystem |
| Frame |
| Dimension(mm) |
| Wheelbase(mm) |
| Min Clearance(mm) |
| Dry Weight(kg) |
| Max Load(kg) |
| Max Speed(km/h) |
| Mini Consumption(L/100km) |
| Tire Size(Front/Rear) |
| Wheel Atmosphere(Front/Rear) |
| Seat Height(mm) |
| Fuel Capacity(L) |
| YG1P50FMG |
| YG100-6 |
| 1-Cylinder, 4-Stroke, air-cooled |
| 4.4/8000 |
| 6.0/5000±500 |
| CDI |
| Electric/Kick |
YG100-6 |
| 1920×775×1080 |
| 1230 |
| 140 |
| 80 |
| 150 |
| 80 |
| ≤1.9 |
| 2.50-17/2.75-17 |
| 225/225 |
| 780 |
| 8.5L |
