Did you check your plug color for jetting? Did you check your main jet size? How about the valve adjustment? Like others have reported here, my valves were too tight on my 2012 from the factory.
there it is , a chrome forward facing air intake (poor mans air ram) , air ram only works if filters an open top like stock filter , mine used a radiator hose Attachment 12885
It was sponggy yesterday and the handle was almost flush with the handlebar. Ironically it seemed fine today. Go figure but common sense told me that it should be firm no matter what right? Brake fluid does not compress last time I checked. Either way replacement is ordered and it only cost me about $25. Cant complain. If anything I have a replacement if I need it.
Sounds like you need to bleed and/or change the brake fluid instead of replacing the master cylinder.
Also spongy can be caused by moisture in the fluid. I'd change the fluid and bleed it. A Mitivac type device works nice to change and bleed the fluid.
Also a trick I have used in the past is to put some strong rubber bands on the lever overnight to get the last bit of air out. You might want to try that first.
barnone,
Will you be putting on the furry seat cover?
So far with the bigger seat on my 2012 I don't think I need the furry seat cover but she likes it.:lol8:
Attachment 12901
It is currently on the W650 which needs it.
Attachment 12902
This is a ruff look of what it will look like. It's gonna take lots of grinding.Attachment 12906Attachment 12907Attachment 12906
my tire don't rub , at max extension my car tire is 1/2" off the fender tip
Hey guys. I tried the stock filter and it made little to no difference on my ride today.. maybe worse but hard to tell. I really have to keep beating on this thing just to keep up with the acceleration of traffic. I know its not a rocket.. but i feel like im dragging something behind me. The engine doesnt seem to break up under throttle.. but it just feels like the brakes are on. To keep up with traffic on a 45 mph road I literally have to keep her full throttle just to manage which is about 45-50 indicated. It really feels like it just doesnt want to go.
I have not checked or adjusted the valves. If you could give me some instruction on how to do this, that would be great. Maybe the air/fuel mix is off.. but the engine seems like it is running through the rpms smooth. As I said before 2012 rtb_a.. weight is 140 and the bike is fitted with 35 rear sprocket. Im running stock spark plug (it didnt like my after market replacement), and 93 octane gas. I replaced the stock filter with an aftermarket one that has better filtration.
Here is a sample of the plug. Phone cant really take pictures up close. Looks pretty clean to me. Not really white and over heated from too much air, and not really black from too much fuel.
Where should I go from here?
http://i924.photobucket.com/albums/a...ps7e9e375d.jpg
