agree Bar , sounds like a tight cable problem
Where did you find the sprocket?
Where do I find the sprocket bolts and a clutch cable for the DongFang Bobber?
Honda part number for the bolts is 90128-382-670
I bought four at https://www.partzilla.com/
I don't know if they are needed but some have had problems with them breaking so I figured I would replace them when I had the sprocket off.
| JT Rear Sprocket JTR279.30T 30 Tooth |
1 |
22.99 |
22.99 |
248591 |
| USPS Priority 2-5 Days |
1 |
0.00 |
0.00 |
| Total |
$22.99 |
From
http://www.oldbikebarn.com/Motorcycle_Parts?search=JTR279
Gearhead45
So after adjusting my valves to spec, I can't get the bike to idle correctly, ides nice while leaning on the kickstand but as soon as I stand it up and turn the wheel straight it idles waaaay too fast. Can't seem to get it adjusted right
If it isn't the cables,it's the float level.I had this issue on my V Star but it has down draft carbs and leans significantly more when on the side stand.
ben2go
Is every problem like what you had on your V Star? I betting on the cable.
The problems I've had on the V Star are due to previous owners neglect and me learning the quirks of the bike.The VStar has dual push/pull cables and it was the first thing I checked.It took a little while to figure it out, but once I did,it was a duh moment.
I also translate issues , with those from my previous bikes , 74 kawi kz 1000 77 Suzuki gs 750 82 Honda cb750f supersport (stupidly fast did 65 in 1st , it could peel u off n toss u off when got on it to hard) 2010 Dong (as the title lists it , and my wife likes to mock "yey he gunna go sit on a little dong for a while") still own da gs750 (need a 2 seater occasionally dontcha know)
I thought you and I talked about this
Price: $18.14 & FREE Shipping on orders over $25. (was 17.89 last week)
http://tinyurl.com/pmrz255
Anywho, i hope it works out, do let us know how that 30tooth in 5th gear does on the slight inclines and flats....
axa
Price:
Hope that photo is wrong on the link you posted because that is not the right sprocket. I've had good success with the guy at Old Bike Barn so I am sticking with him. How much does your guy charge for shipping?
