Thanks so much!!! Any ideas on a clutch cable replacement other than custom?
thats the sprocket, photo is often wrong with Amazon...
shipping is free with a $25 purchase, 2 day free if you have the prime service.
sorry i thought everyone knew about Amazon, I always check there first as their volume drives prices thought the floor.
Full disclosure, owned the stock for almost 15 years
Have you been able to find the washer and circ clip that holds on the sprocket?
No. Just looking for back ups. Felt like I was going to break the clip when I removed using needle nose pliers in reverse. How did you take the clip off?
There is something called a snap ring plier, rings are often very difficult to remove otherwise. Use them and you wont likely damage the ring.
This set is a real deal for this size ring, i cant fathom what the few bad reviews are all about.
http://www.harborfreight.com/10-inch...set-97406.html
so how many miles do you other 2012 drivers get before needing a fill?
I seem to get close to 95 (make that 105), indicated, of course there is a notable amount of gas left in the tank, just this tank seems to push it back, and has the petcock mounted a bit high and forward.
I got 78 MPG and 81 MPG on the last two fill ups on my 2012.There is almost no stop and go traffic here in the mountains. I put two gallons in to fill it up when my tank was new and empty so say 120 miles should be safe assuming there is gas not too far away.
What kind of MPG are you getting?
I get around 60 in town and 80 and trips to the country. Madison WI
