The wall thickness on my GS engine is 1.95mm with 10.5:1 compression and turns 13,000 thanks to aftermarket valve springs.
So I finally got the DF out on its first street ride, and the damn speedometer isn't working. It's getting power, both to the LCD display and to the turn/headlight indicators, but the speedometer needle and odometer aren't working. Any ideas on the possible cause and fix? I checked the wiring from the male-female connector down to the front hub, which I assume is the mechanism for the speedo. Ran out of daylight though, and I'll give it a go in the morning.
I haven't gotten too in-depth with troubleshooting yet, BUT, the cable appears to be an electrical-sensor type and not a mechanical speedo, as one end goes to a 3-wire connector.
My 2012 DF's speedometer is a mechanical one with a drive cable. Forget what the one on my 2010 was but it might have digital with an electrical pickup on the front hub like the one Woody is describing.
It is hard to tell from the parts list at http://www.scooterdepot.us/parts_htm...arts_list.html
Found a possible cause. The speedo will work with the engine off, however, when the engine is running the needle won't budge one bit. Clutch adjustment, maybe? I used an electric drill with a flathead bit and was able to spin the hub-drive end up to about 20mph.
Key on, engine nor running, spinning with drill motor and it works. That is weird.
The speedometer did work when you took your driving test,right?
Don't see how the clutch adjustment would have anything to do with it. Coasting at speed on bike with clutch in and speedometer works?
Engine running no work says it has something to do with charging?
