that would be the first ive ever seen when more air equal less HP :D lol how far is orlando from jax?
so leaving the airbox on is better? i just remember racing MX i used clamp ons
Removing the airbox and on these CV carbs will kill your power for sure. CV type carbs have to have a certain volume of air flow to work correctly.
Just by an aftermaket racing filter and put it in the stock airbox.
what about a larger carb?
You could put a larger carb or even a different type of carb...there is alot of talk on here about slide carbs.
If you went with a slide carb you could stay the same size as stock and actually gain air flow because of the way they work.
Here is a link about carbs: http://www.mychinamoto.com/forums/showthread.php?t=783
Here is a link about aftermarket air filter: http://www.mychinamoto.com/forums/showthread.php?t=775
yes i dont mind doing this but a 30mm mikuni slide carb is only 39 bucks new on ebay
You have to remember that the carb we have is 28mm and so are the mounts. If you go with a bigger carb you will have to try to find a bigger rubber mount for the engine side as well as the airbox side.
