3 Attachment(s)
Re: Are Benelli bikes big fat lemons....
So, on removal of all the trim, I found that the bolts for the front fulet tank mount had sheared off:
Attachment 18800
And it seemed real strange, the mounting bracket was up in the air. I could not even push it down to fit on where the broken bolts where sticking out. It was only after I removed the tank and looked underneath it that I could see the problem. Both bolts holding the top of the rear frame assembly had sheared off so, rear the frame pivoted on the lower mounting bolts. Since the fuel tank rear mount is attached to the rear frame it pulled it along ripping the front tank mounts from their bolts. the red arrow in below photo points to where the rear of the fuel tank mounts on the rear frame (and you can see how far away the rear frame assembly mounts pivoted away from the main frame.
Attachment 18801
And here is the spacer that fits between the rear frame assembly legs, the remains of the sheared off bolts can be seen protruding from each end
Attachment 18802
continues next post...
Once again Bill what shame.
The technique to entry or bye pass a toll barriers is a well sorted out way which I have used many times over the years and I am happy it has help you at a time when you most needed it.
Looking forward to your next post to find out the root coures off the leaking Tank.
This trip is turning out to be the 1 you remember the most, not because of the great mountain you have
viewed but because off all the problems you have had with the bike.
Take note people who are considering a ride such as Bills.
DO NOT CONSIDER ALL ROAD ACROSS CHINA
TO BE LIKE YOU HAVE NEAR YOU HOME LOCATION.
As Bill have just found out some are in very poor sate of repair.
My advice is to ride a bike which is capable of handing the bad stuff with easy so when you hit the good stuff it's a dream.
Well good luck Bill and keep the thread updated with your progress.
5 Attachment(s)
The temporary repair starts with finding something to prop up the back of the bike so I can line up the rear frame assembly with with the main frame to re-attach it.
Attachment 18803
Then go to town to get the studs extracted from the spacer. A local shop welded a piece of rod to the studs and unthreaded the them.
Attachment 18804
In this little town, all I could find are soft steel hardware store bolts without an allen head. I had to get slightly longer bolts and add nuts as spacers to I could fit a wrench on the end of them to tighten all the way into the recessed frame.
Attachment 18805
This won't take care of the problem if the original hardened steel bolts sheared. But, it should be OK to get me 65 KM into the city (with no luggage onboard) to buy better bolts.
Attachment 18806
And now it is attached again:
Attachment 18807
And now, while waiting for the new fuel tank to arrive, I am cruising on my local rental bike.
Last photo not attaching, posting now before I lose the post...
3 Attachment(s)
I now suspect the cause of the first leaking fuel tank was that one of the bolts holding the top of the rear frame assembly sheared. This caused the rear frame to pull back on the tank and overstress the weld (rear tank mount welded to tank) causing a leak. but with still one bolt holding the rear frame I did not notice that the other bolt was broken. Although, what Prince pointed out, the number plate being out of alignment with the rear tire, was an indicator. Then once back on the road hitting more bumps, finally the second bolt sheared, ripping the new tank apart.
I can't believe I drove the bike in that condition, with all my gear loaded on the back, for 1100 km. As far as I can tell, the only thing holding up the tail section of the bike was the exhaust pipe and muffler assembly.
Now lets see if |I can post the photo that failed on the last message:
Attachment 18810
yes, OK, one more photo. Here are the rear flashers that broke off after hiting the rear tire
Attachment 18809
now zap strapped to the luggage rack. And they are still working, even after driving like that about 500km worth in the rain!!!
and this last photo is just a ghost that won't go away. I can't delete it:
billeuze, I hope you don't think I'm picking on you, I'm just trying to point out some things that I see from the pictures so others can learn and avoid problems while on the road. I'm puzzled as to why you don't think your bike is completely overloaded? It is, and further proof is having the sub frame detach from the bike. I'm so sorry to see you're having these troubles, it's frustrating when you're trying to keep a schedule and bike problems keep getting in the way. I must say, you're attitude seems to be pretty laid back an optimistic, perfect for dealing with the frustrations of China. :thumbsup: Good luck moving forward.
Hi ChinaV.
MCM is a great source of information with regards to riding around China you and ShuBun have been riding in China for many years and like me know to well what is the best type of bike to ride China.
You are correct Bill is,a very laid back man and I take my hat off to him for his positive attitude.
You are correct to point out in your mind you consider MAYBE the bike is a bit overloaded ?
I don't think for one minute Bill thinks you are digging him out he is too nicer guy for that.
We all wish Bill well and hope he can complete his ride.
But something tells me this is not the end that why I started this thread.
IMO he needs to unload some stuff and send it home.
IMO he need to keep on the Toll roads from now on.
I am very concured and worried about his progress from now on considering what has happen to the bike over the last week and I have ask Bill to keep me updated daily by way of WeChat.
Good luck. I hope the trip goes smoother from now on. You have paid your dues.....
This is some serious stuff! People usually get punctures and broken spokes and you rode over 1000km with your frame in pieces. Its kinda funny but was definitely dangerous. This is something you can not predict. This bike was simply not designed to carry luggage. Good luck mate, hope everything will go well from now on
