Here is a diagram on how it works.
http://www.dansmc.com/starter_clutch2.jpg
There is a clutch on the back side of the charge rotor that is made up of 3 rollers with pins and springs pushing them out. Are you talking about the flywheel as being the charge rotor? Forgive my lack of tech. Also another question.. when turning the crankshaft bolt which is the proper way to turn it, clockwise or counterclockwise?
O.K. I get it, your talking about the overrunning clutch assembly as shown on the DF parts list diagrams. I did not think about that. Maybe it is not engaging as it should. I will check that.
Still wondering though, should the engine be turning clockwise or counterclockwise.I do not want to mess anything up when going TDC.
retracted.
cool thanks Bar. I was pretty sure of that..but ya know when you go knee deep into stuff and then your kids come by and start asking a million questions, sometimes you get distracted.
Just for a couple of references would anyone know where I could find a replacment engine if needed? Add to that a how to on doing the charge rotor. I am pretty much on my own with this thing except for all the input that y'all give..which is greatly appreciated. But..I am looking at the cost of everything involved. Options are always a good thing ya know.
Basically my wife asked me what a new motor would cost seeing as how this one has over 11,000 miles on it. I know they do not last forever. Thanks.
Unbolt the charge rotor and the starter clutch is bolted to the back of it.The big gear behind it free wheels on the crankshaft.You will need to hold the engine still to remove the charger rotor bolt.I used a chain wrench.Some put the bike in gear and hold the rear brake pedal down.The bolt goes back in with red loctite and roughly 80lbs of torque.Make sure the bolt hole,bolt,and charge rotor hole is clean and dry.They can spin on the shaft.Mine did and it welded the gear to the crankshaft.I had to use a gear puller to take it off.This is on my GS500 when it had an all stock.
http://i205.photobucket.com/albums/b...f/100_0125.jpg
http://i205.photobucket.com/albums/b...f/100_0130.jpg
wow, looks relativley simple enough. i will give it a shot. Thanks. I am not a motorcycle mechanic, I have more experience with small block chevy's. but I am mechanically inclined.
