I would not weld the tank to the frame. Bolts with rubber pads like bowtie used looks fine to me. If you are worried about tapping in the tubing holding, how about through bolting with curved washer underneath?
Bar, i do not think he meant welding the actual tank to the frame, but perhaps welding a nut to the frame to attatche the tank. I was thinking about doing that, and I may still. I also considered going through the frame , to make sure it would be on tight enough with all the vibrations and being a hradtail it takes some abuse. with the terrible roads. I am watching the mounting choice I have made, to see if I need to tweek it any. So far, it is good.but I am still concerned about the actual lack of threads due to the thinness of the frame itself.
Maybe I can get a small steel tube, drill through the frame, add the tube through the frame then bolt through the frame.. leaing the tube to be a more reinforced replacement for the lack of metal drilled out for the bolt. work in progress.
Just wondering, has anyone had a flat tire yet? I have a small staple like thing in my rear tire.. saw it this morning.I am going to just cu the excess off the wheel and leave the remainder in it until I get home. But just wondering how thick these stock tires are. I had a pretty decent size tack stuck in the front wheel a couple weaks ago, pulled it out, but have not lost any air as of yet. I guess if I loose air I can always plug it. Any thoughts on replacement tires? I know these are tubless. Haven't look any up yet.. may do that today just for giggles.
bowtiewagon
Yep, I probably misunderstood but mentioned it just in case...
Knock on wood, no flat in years on any of my vehicles. I carry a can of fix a flat in the tool roll on the DF.
