Did you have to cut off some chain links to go with that sprocket? Does the stock chain have a master link, or is it an endless chain?
I have the same question about the chain length fitting the smaller sprocket. My chain has a master link so it should be a problem getting it off
Change the part number to JTR279-32
http://www.amazon.com/s/ref=nb_sb_no...ords=jtr279.32
Seem to remember that I had to take some links off. It is a master link chain. Get some 520 chain master link repair kits in case you screw up.:lol8:
Attachment 16979
http://www.amazon.com/PARTS-UNLIMITE...ain+repair+kit
Got a chain breaker at Harbor Freight.
Attachment 16978
http://www.harborfreight.com/heavy-d...ker-66488.html
They are wanting some cow pellets.:lol8:
Attachment 16985
Likewise some that we have at our place here in town. Our new grandson is not impressed with the heifers.
Is this dongfang? Finally avaible in Poland.
http://www.ccw.com.pl/
http://www.motocykle-125.com.pl/wp-c...-hiest-125.jpg
That is a CCW Heist and not a Dong Fang but it is a very similar motorcycle.
There is another thread on My China Moto for the Heist.
http://www.mychinamoto.com/forums/sh...-CCW-tha-Heist
my df250 carb is running full force and the idle screw does not do anything. Any suggestions would be appreciated. thanks
I took it apart and cleaned it with gum out. Could the accelerator pump be stuck?
The idle screw turned clockwise slows the engine normally?
This is just a stretch, but it happened on mine... Check where the throttle cable enters the hand grip area. Mine got pulled out a ways, and then stuck out. It made the motor run at WOT. All I had to do was pull it out a little further and re-seat it back into the opening.
Attachment 16986
