Put some ammo cans on the DF.
Attachment 17602Attachment 17603Attachment 17604
can someone link me to a new 167fmm Neutral Sensor?
also does anyone have an extra pz30 choke lever? i have some 105-120 jets to trade
I'll have to check the size. Don't remember where I got them. I do have one 30mm but they are too big for my bikes. Some mount the 30mm under the sidecar on the Ural.
Attachment 17627Attachment 17628Attachment 17629Attachment 17630
Military Ammo Can 5.56 mm 12"x7"x8.5" 800 CRTG 5.56MM
That's a good size for small bikes.
Little wet on the Dragon today but still a good ride.
Attachment 17643
Has anyone ever found a replacement rear master cylinder for DF250? or a offbrand that fits?
Are you sure yours is bad,and it's not just air trapped in it?i have seen many good brake parts replaced due to trapped air.If you bleed the brakes the traditional way,by pumping the pedal and opening the bleed screw,try raising the rear so the air can travel up to the highest point easier.
