bowtiewagon
interesting. I have searched for how much to put in, but you know how it is with this bike. Trial and error. I think what I might do,it disassemble one old shock, pour out the oil and estimate how much is in that, then go from there. hopefully that will give me a figure that will work.
I would do both and get an average. Then add just a ouch more. Some fluid gets trapped in the bottom of the fork slider under the dampener rod.
bowtiewagon
that's the carb but sure you cleaned it properly...
I only say this for it's likely dirty or a leak.
find some fine wire and stick it through the jets. and look else where for a problem like exhaust seal or intake manifold leak.. not too many issues can't be solved rather than replaced.
that said this new rebuild kit has everything.
http://www.ebay.com/itm/272689779764
the jets are pretty close if ur not picky.
without a slide, cheaper
http://www.ebay.com/itm/291807976434, but no description of jets.
or if u insist the whole thing cheaper than you posted.
http://www.ebay.com/itm/322477941584
if u don't want accelerator pump, which I find off little use,
then u can have it for 16.99 all in.
that said I'd send u mine for the cost of shipping... Im running a D slide type carb now...
axa
Thanks I will keep all this in mind. Gonna focus on the shocks right now.
Hi new to the forum reading about these bobbers,the heist and the dang fang ....Whats the difference in the 2 and are the fork rake the same?thanks... Mike
mikec123
Hi new to the forum reading about these bobbers,the heist and the dang fang ....Whats the difference in the 2 and are the fork racks the same?thanks... Mike
They are pretty much the same bike. IIRC, Dong Fang make them both. The hiest just gets a little more detail paid to it. I'm not sure what you mean by the fork racks. There is, or was, a Heist thread on here. You'll have to try a search for it.
It looks like the heist has a more raked look more chopper like look know what I mean? Thanks for answering my questions I say there the same bike basically and the dong fang is more than a thousand dollars cheaper I'm all about that!! do you know of a list of dealers here in the states?
mikec123
People have been having some luck with PSM. http://www.powersportsmax.com/index.php/cPath/482_483
There is a thread on www.chinariders.net about good and bad drop shippers. There are no true dealers in the US. Only some that set up and sale as a retailer.
I really wish someone would wake up and start selling replacement engines for these bikes. My new motor still runs fine, but it was not easy to come by.I got lucky locating it. If they sell the bike, they should offer parts as well... including engines. Just saying.
bowtiewagon
what u really want is a 400cc - 500cc with a cg footprint I wish someone would wake up and produce that.
you can actually find the cg250 just not always if ever in Black.
I've replaced the head twice and cylinder once, both times I had to do the paint.
Guys, is it really hard to find some CG clone engine even in the US?
