Easy to make one with piece of 1/8" or so thick aluminum. . Remove the pipe and use the gasket for a pattern. Need to cover the vacuum nipple in the carb area where you removed the hose.
Attachment 19718
Better photo off the net.
Attachment 19719
Attachment 19718
Attachment 19719
Removing the air injection system will get rid of the popping on deceleration plus the engine should run a little cooler. If you are going to maintain a DF you need some basic mechanical skills. Buy an inexpensive hacksaw,drill, and some drill bits and make your own blocking plate. Aluminum is available at your local hardware store. Easy peasy!
Also do a search on this thread for examples of any questions you have. It has almost all been done before.
CG CB based motors? Taobao sells those blanking plates for 5¥
【我剁手都要买的宝贝(发动机排气堵头 发动机欧二排气堵头 RE250发动机废气管堵头 挡片),快来和我一起瓜分红包】,复制这条信息¥m61R0WD0rgW¥后打开👉手机淘宝👈
https://uploads.tapatalk-cdn.com/201...bf23153d92.png
My last bike I fitted the plate etc under original fitting so looked connected but no function
