MJH
The Chinese cannot manufacturer higher quality products the same way they manufacture the low quality products. A high quality product shares nothing with low quality products, they cannot use low quality components for a high quality motorcycle. The Japanese partners will not allow an electric component to be used that is not bench tested. They test and record all of the installed components, if they buy from a supplier they require demonstrated tolerances and if not adhered to they will change suppliers. If none exist then the part gets imported.
Every criteria required to manufacturer a better product cost more.
If it is totally new, then it really cost much more to make in every aspect at every step of the process.
If you buy what is legitimate and in that all new and tested, developed exclusively with high standards you will get a better product.
If you buy something that includes cheating the process at any level or stage, and believe they will not also cheat you your mistaken, because they will, part of being inept, immoral and incorrigible at any level corrupts everything at all levels, including the purchaser.
