:icon10:
LX450 is my second Enduro from China, I received it a couple of weeks back and took it out for a spin.... In offroads it did wonders.... but had lot of vibrations in handle while on pavements..... I am unsure what top speed it can get on straight out topgear...
Attachment 20054
thats freakingly high speed.... I check with GPS the KOSO meter seems to be quite accurate but above 80kmh the vibrations in handle bars is like the handle will break into two pieces any moments so i have to dethrotle it...
Also gear ratios seems to short bike asks for 6th gears... its 13X48 on Final Drive....
@vickytulla: your vibration come from the rim lock that is installed to avoid tire slipping on the rim. I know this effect from several bikes. You basically only need then when you ride with reduced tire pressure.
If you don't do that remove them.
BTW: it helps a lot to remove the front one only. Then try if its necessary to take out the rear one too.
Important: close the holes in the rim with a rubber plug or duct tape from inside to avoid dirt getting in.
I don't get any feeling of instability up to about 140. After that it can start to get a little scary. It does beg for a sixth gear which I'm always searching for, but.... I don't want to be driving over 120 anyway; I just want to be able to blast past big trucks and traffic and stuff on the highways with a flick of the wrist. Love the torque on the thing...
