Re: SHINERAY HUSQVARNA branded S.W.M
Surprised?? No....What kind of results do you get on your GS with your riding style? I saw some of your style last year as you departed the local "rest stop" and figured you were having a blast with much more fun than any steroids could ever
give you!
Hello I have swm rs500r what are the restrictions on this bike it doesn't seem to be clear I see only in the manual 20kw /38kw race
ShuBen
They limit throttle twist, reduce air intake flow with a plastic cap, have a device installed to avoid gas fumigation(??? For whatever) and the O2 sensor.
As I learned the sensor is not really a performance killer but part of the data input for calculation optimizing gas injection. I will put that in again.
Thank you for your reply I will have a look at my bike I did think that the throttle twist was short. The bike does feel restrictive I will have a look at the air filter as well. I have just ordered the single arrow exhaust so I hope I will see a difference in response and performance.
Hunty
Good evening I looked at my bike today and on the plastic air filter holder did you take the plate off which was held on with the three torx screws?
I also looked at the throttle assembly under the tank and can see that there is a plate which does stop the throttle so I have now removed it.
Thank you
ShuBen
As I remember I took off a big plastic cap and a related plastic ring with size of the cap ....
How does your bike run now?
Thanks for the reply i will try at the weekend once I get the arrow exhaust it should feel like a different bike .
ShuBen
Today I re fueled the RS500R.
In fully open condition it used 6.4L /100km 😱 .... Must buy a gas station.
OK, I am not what one calls passive rider, but...
I will do 2 more refilling rounds in this condition and then re install the O2 sensor and see what's happen then.
Just read it would reduce power by about 5% but also optimize fuel consumption.
Let's find out
You can get a bigger tank from here.http://www.safaritanks.com.au/home/s...50-310-450-510 from memory there were companies making a rack that went over the rear mudgauard as well.
