Re: Zhejiang Jiajue Motorcycle Manufacturing Co.,Ltd.
Puzey out of South Africa is offering the Jiajue copy of a KTM Duke with the Zongshen 279cc SOHC 4-valve as their Atom 300.
http://i784.photobucket.com/albums/y...tom-300-02.jpg
| 46,990.00 ZAR |
3,049.05 USD |
KTM Duke 390
http://www.motorrad-testbericht.at/m...duke390-04.jpg
| 58,999.00 ZAR |
3,828.27 USD |
WK distributor in the UK is discounting its inventory of the Jiajue N10, both versions they offer in either as a 125cc or the 249cc DOHC water cooled, SP250N, are being offered at the same prices.
http://i784.photobucket.com/albums/y...0N-BLACK_1.jpg
| 1,499.00 GBP |
2,159.23 USD |
The N10 can be configured with either the NC250 Zongshen or the DOHC 250 manufactured by either Yingang or Shineray.
They likely have a time frame to clear out inventory due to changes in emmison regulations. These are actually a bargain...the next version if WK continues to offer these will have to have EFI and ABS.
A division of Jiajue is Motrac, they are planning on offering a 400cc twin called the MT400
http://i784.photobucket.com/albums/y...f68c962646.jpg
That 400cc looks very different then the 400cc Jiajue is offering in its N10.
The model is labeled with WK which might mean they will be offering it in the UK as an A2.
http://i784.photobucket.com/albums/y...e93df91c17.png
The engine in the N10 looks like the water-cooled 350 offered through Jonway?
| MODEL N10 |
| L*W*H 2030x709x1127mm |
| Wheel Base 1369mm |
| Seat Height 800mm |
| Fuel tank 20liter |
| Suspension front up-side-down ,rear single gas shock |
| Brake front dual 300mm, rear single 220mm disc brake |
| Tire front 110/70-17,rear 150/60-17 |
| Speedometer digital |
| Starter electric |
| Net Weight 150kgs |
| Packing 2020*570*1180mm |
| Conatiner46pcs/40HQ,20pcs/20FT |
| Engine Type JS400 In-line 2 Cylinder |
| Engine 400CC Water cooled,Double Cylinder Parallel 4 stroke,4 valves |
| Bore*Stroke 63.5 * 63MM |
| Max Power 26.2kw/7600 |
| Max Torque 35.6N.m/5500 |
| Transmission 6 gears |
| Max Speed 170KM/H |
| Pressure Ratio11:01 |
Here are the advertised specs on the Motrac 400, they have the same numbers and both 399cc. However the images are of what look like very different engines. Also the versions of the Jonway and Lifeng 350 that are offered currently are actually under 350cc and these are actually 399cc? Also the previous versions at of the twin at 320cc has a bore and stroke of 62x53, so these are more then bored out versions of the previous engines.
http://i784.photobucket.com/albums/y.../Motrac400.png
Hmm...
It looks like more than modified old "Honda" twin we saw on, for example, "Lifeng's" bikes.
"Jiajue" is outsourcing engines - that is clear, but who's been keeping this engine under the radar so far?
Some extra pics and info, not much, but still... http://bbs.86516.com/thread-6360729-1-1.html
Things are starting to get interesting...
It is not clear who is the manufacturer behind Motrac, they seem to have displayed their 500cc twin in a show recently. Also announced future V-Twin 800cc model, a cruiser.
http://img2.newmotor.com.cn/UploadFi.../26352/sdf.JPG
