Re: My blog of a Pulse Adreneline 250...
ianmrr2301
Hi
Well I eventually got my hands on a shiny new Adrenaline 250.
So other than a couple of niggly things very happy.
Will keep you posted.
Regards
Ian
Hey, congrats on your new bike.. :thumbsup:
Serpentza
I have recently been on an epic adventure through three Chinese provinces, I'll post a link to the RR once it's up... great bikes these
Looking forward to your adventure Serpentza..
spencer2004
Do you know what each device draws and the voltages they run at? It may say in the manuals.
Hey Spencer, Thanks for your idea's. I had a look for specs too, couldn't find any. I have a vest, insoles & gloves. it would be cool if I could attach them all, but would settle for vest and insoles as I have heated grips..
The Oxford Lite Grips I have draw 3amp on full, and they are too hot to keep at that level, so presumably they may draw 1.5 - 2 amps on low setting.
I cant see the vest or other items getting as hot as the grips (Well I hope they don't).
Following on from your post I have taken the plunge and ordered one of these:
http://www.ebay.co.uk/itm/V1NF-12V-2...item3384f92f19
Only cost a few quid - so worth a shot... The only problem is wiring up the heated stuff, they have thin wires and a tiny plug...
WirralGhostHunter
USB charge point and new clock sorted.
Attachment 12898
I noticed rubber blocks separating the cooling fins ???
Attachment 12899
Nice surprise of Lithium Ion battery ?? Hmmmmm. New lithium charger cost - in excess of 100GBP - F*CK!
Attachment 12900
I got these rubber blocks in mine? anyone know why they are there..
3 Attachment(s)
Time line update Sept 2013 (1)
Added a few knick knacks to my Adrenaline.
The first is a cheapo talking watch (waterproof too) as my nice oxford time piece was stolen......
I had a good experience with a "White Light" replacement bulb that I installed on my Jetmax - so much better than the standard yellow halogen. So another went in here...
I was fed up of struggling with the valves when topping up with air - these little 90 degree jobbies are just right..
Attachment 13548
Attachment 13549
Attachment 13550
4 Attachment(s)
Time line update Sept 2013 (2)
The standard horn was to say the least - a bit weedy....
So time for an upgrade.
Enter a compact(ish) air horn.
Hmmmm... Not as compact as I would have liked. No room at all where the original was fitted. In fact no room at all under the tupperware..
Instructions say keep away from engine heat and water.... I was thinking this is going to be a non starter...
Any way - all the plastics off so I could take a better look.... No chance!
Off for a cuppa... Brainwave - under the seat - maybe!
Things were tight - but not going to give up..
Another cuppa - brainwave number two... Suspend from a bracket..
Some digging about in my toolboxes yielded just the piece of metal needed..
Right then test fitted - looks good..
Route the cables and relay - nearly there..
Attach cables and secure everything - DONE!
Now test that horn:
L - O - U - D
Great - put everything back together...
Seat wont go back... Needs triming because of the horn and bracket ...
Five minutes with the Stanley knife - all sorted..
I will have some fun later..
Attachment 13551
Attachment 13552
Attachment 13553
Attachment 13554
3 Attachment(s)
Time line update Sept 2013 (3)
Great as this bike is turning out to be - the one thing I am missing is storage. I was spoilt for choice when I had the Jetmax - caverns abounded..
I purchased a 56 Litre box for it - luckily I took it off when it the Jetmax was due to be humanely destroyed..
I tried to "tinker" a way to fit it to the grab handles - NOPE! Wouldn't have looked good.
Where on earth am I going to get a rack ?
Looked on CMPO just in case - lo' and behold they stock them..
Couple of days later it arrived - not long after - fitted...
A little bit tight in places - but I can live with it.
LUXURY - I now have my massive box installed... Love it....
Note: I also fitted some "intense" aux tail lights to the reg plate... I'm going to make sure I'm seen front and rear...
Attachment 13555
Attachment 13556
Attachment 13557
3 Attachment(s)
Re: Time line update Sept 2013 (3)
Time line update Sept 2013 (4)
As winter is drawing in, I need to sort something to keep the wind blast away from the back of my hands. Inside will be toasty warm thanks to my heated grips.
I tried a set of guards that only secured inboard - they turned out to be rather cheap and nasty - and not all that secure.
Another rummage on Ebay - found just the ones.
Took a bit of fettling - but it paid off.
Now the chill is deflected - and my Adrenaline has take on a more muscular stance...
I may even try getting the handle bar muffs on..
Attachment 13561
Attachment 13562
WirralGhostHunter
I thought that too. It is the tyre dressing the dealer put on. They are made by a company called Kingstone. To be fair, they look decent enough - will let you know later how they perform...
Will keep you posted :thumbsup:..
I've still got my WK 650 - got this one to keep me on two wheels thru' Autumn & Winter - I hope...
I must have ya'll know as soon as now; Kingstone tires are the most slippery. :D (at least from my experience)
I do stunts (and you know burnouts and drifts are part of them)
