Like I said before. Im new to bikes and carbs unfortunately. Anyway you could snap a picture of that screw so I know what one it is? Thanks for helping guys
No biggie mk2, this is how we learn... I'm new to bikes and carbs too! Couldn't pick a better bike to learn on right?
I'll dig up the link to a carb how-to I put together. All the adjustments are covered in it I think....
Edit...
My Bad!! the how-to was for the jets only.
So.... the idle screw is hidden on the side of the carb behind the throttle cable and accel pump assemblies. It is NOT the visible screw holding the cable guide on. It's tucked in behind that. Turning in will raise the idle, out will drop it down. Turn it slowly and use your ears to find a smooth idle. I'll see if I can point it out in a pic somewhere.
After you get it started and running you will have to adjust the carb's a/f screw to get everything dialed in. Tom can walk you through it over the phone probably.
http://i1090.photobucket.com/albums/...t/_DSC6672.jpg
Here is the larger visible screw holding the assemblies on. The Idle screw lives behind there. Kinda have to snake a little screwdriver in there to get at it.
Thanks for the picture kevin! Just called tom, he said that all I need to do is adjust the idle screw. He has everything else set as far as air fuel goes. Now I want to be off work even more!!
Adjusted my carb the other day and the bike is running much better, still popping a little during downshifting. Finally getting a little time to ride and the bike seems to be waking up a little as it gets some more miles. Another hundred and I'm going to see Tom for the first service and a once over.
What tire pressures are you guys running front and rear? I think I'm at 30psi front. That rear tire is a PIA to get any of my gauges on because of all the spokes.
How's the site going Gardo? I'm sure you've got a list going of all these little handy specs.
Ok, my G&D long pipe just arrived in the mail, and I will be wrapping it with exhaust wrap and installing it... but I have a very noobish question... here goes... should I wrap it and put it on, or should I put the heat shield (off the stock pipe) on it and wrap over that too for extra heat protection in that spot (so my boot heal doesn't melt)? Thoughts? Personally, I'm leaning towards just wrapping it as-is with no heat shield, as I believe that the wrap will offer enough protection, but I would like your input. Also, I'll be posting pics at some point, but the bike is just too stock at the moment and I don't want to post a pic of another stock heist until I get some of the other mods done first. THANKS!
Wrap the pipe first dude. Put the shield on or don't, but wrap it first.
EVERYONE post up some pics! Just wanna see what you guys are doing with these bikes!
http://i1090.photobucket.com/albums/...t/_DSC9573.jpg
Can't have too much Widow bro. Post up. I was actually just thinking how good this NGK wire would look on your bike. Fits the red theme and all.
http://i1090.photobucket.com/albums/...t/_DSC9568.jpg
It's pretty much the same as last week when I got it but I found some coke bottle grips and just stuck 'em on tonight. If my exhaust wrap shows up in time I hope to wrap it this weekend. I'm looking for a particular decal to dress up the tank, but so far I can only find it online in the UK. I've got plans for a kickstart lever that involve welding (which I don't know anything about so I'll have farm that part out). Unfortunately I don't know what kind of metal any of the known levers are made of and whether or not they're suitable to be cut and welded.
Attachment 5202Attachment 5204Attachment 5203
