4 Attachment(s)
The Moriarty MKII, a new project bike for a friend
A good mate of mine Pete (actually the bloke who bought the Churchill) is in the market for a new bike... I built another bike... but I wasn't happy with it, it's a great little performer, but he wanted something he could potter about with his bird on the back and also something with power and practicality....
Here's a picture of the bike I originally built for him but wasn't satisfied that it met his requirements (so it went to C-milk who can appreciate its performance orientated stance and handling).
Attachment 13881
I happened to be wrenching on this bike at my local bike shop when I saw a GN125 clone stripped down for fixing and it clicked... This is the bike I want to build for Pete, it's bigger, more comfortable, safer and much better for carrying a passenger.
So... enter the piece of shit canvass:
Attachment 13882
It runs.. but that's not important since I'm going to toss the engine anyway...
Why did I choose this rusty piece of crap? Well simply because the frame is salvageable, it has a new tank, the rear tyre is newish... and well because it's the right shape....
The first thing to do was to get rid of all the rust on the frame... this was done using a wire-brush attached to a grinder... I managed to also remove several layers of skin off of my one hand in the process (pain is for the weak).
Attachment 13883
After removing every bit of offending rust (there was a lot)... I had to turn my attention to that awful swingarm:
Attachment 13884
It was completely rusted through... and the swingarm bolt was rusted in place... I had to cut the bugger out with a grinder...
Coming up... things start to look better
- SerpentZA (youtube.com/serpentza)
4 Attachment(s)
Re: The Moriarty MKII, a new project bike for a friend
We continue...
Long story short, a new swingarm, a pair of new rear shocks, and a fresh coat of paint on the rear frame and it ended up like this:
Attachment 13885
What an improvement... but it took a lot of bloody work :P
I put the rear wheel back on (I'll be taking it off again tomorrow to clean and respray it)
Attachment 13886
Next, I cleaned up a lot of the bits and pieces and then put it all back together... I was knackered and needed to call it a day....
Here's how the bike stands at the end of day one:
Attachment 13887
Starting to look like something...
Attachment 13888
Tomorrow the engine gets tossed and a lot of changes will happen to the front end... stay tuned...
good choice for a potterer/putterer. Those things have comfort as their main attribute and reliability as a back up. Going to go for the 250 implant?
zhu
Yes, already ordered a 250cc Shineray engine.. I love those engines :P
What do you use to get rid of all the rust and aluminum/chrome oxidation? Seems it work really well. My bikes engine is a bit oxidized and I cant find good product to remove it as all the recommended ones are western and hard to get here. Have no idea about the Chinese ones
modron
WD40... I bathe the bike in it and then scrape off the crud with steel wool or something similar... basically oil is the key ;)
5 Attachment(s)
Today was pretty productive... I started to work on the front end of the bike...
Firstly I have to explain that the entire front end of this bike is rubbish... here's what's wrong with it:
The forks are rusted pieces of crap, the speedometer and tacho are garbage (and don't work either), the triple tree/clamp is rusted and gnarly and the headlight mounts are rusty too... oh and I didn't mention that the speedo cable and the cable driver are seized and rusted too... basically the whole lot is garbage.... so where do I start?
Attachment 13934
First thing was to remove the headlight so that I could get at the bolts holding on the speedo cluster... I could also get a closer look at all the rusty goodness that lay beneath...
Attachment 13935
This bike has seen better days... actually... being bought by me is probably the best thing that has ever happened to this poor neglected turd...
Attachment 13936
These are absolute garbage, maybe they worked once... way back in antiquity, strange thing is, a pikey at the shop almost tripped over himself with joy when I gave them to him because they "looked more beautiful than the ones on his bike".....
Attachment 13937
Next I took all the rusty bits and brushed them down to bare steel with the steel brush/grinder combo (be careful with this, not only did I remove a lot of skin yesterday... but today ended up with a lot of wire splinters in my leg hand and even my cheek...)
Attachment 13938
Here we can see some of my bits after their first coat of paint (more coats and a clearcoat were to follow later)....
Next we take care of those disgusting head bearings....
4 Attachment(s)
When taking off the triple clamp/tree, what was left of the crusty head bearings all fell out... they were rusted garbage in any case...
So... good time to replace them:
Attachment 13939
Worn out and rubbish...
Attachment 13940
brand new shiny head bearings :)
Attachment 13941
You can't just install them raw like this, they need grease... so here comes the grease...
Attachment 13942
Top and bottom all greased up and ready to be re-installed...while I was doing this, I ordered the new front forks...
In the next part the new front forks arrive...
3 Attachment(s)
Right, so the new forks were perfect, I put them on and now that everything was cleaned up and de-rusted things were starting to look good:
Attachment 13945
The brand new forks and the nicely re-sprayed/de-rusted everything really go well together...
Attachment 13943
Look at this rubbish disc brake... unacceptable! (so is the wheel rim... but sanding it down and re-spraying it is tomorrow's job)
Attachment 13944
Ventilated discs are sooo much better.... remember this bike is going to be a 250 so it'll need that extra cooling!
Next.... the whole front end comes together!
5 Attachment(s)
Since I have to take the wheels off tomorrow anyway for a respray, I just loosely put the front back on... I then added my special speedo and extra special indicators...
Attachment 13946
My new speedo bolted on with no problem, it is a very basic unit... but I like it that way, it has a trip meter, a speedo, a high beam indicator, turn signal indicator and a gear position indicator which shows: 0,1,2,3,4,5
Attachment 13947
Next, the new handlebars were attached, they're much nicer more aggressive and lower than the original GN wannabe cruiser shyte, I also added my nice rubber grips and kill switch/ignition thing (note that it's exactly the same as what's on the Shineray X5... )
Attachment 13948
The wheels will be resprayed tomorrow and this front tyre is going to be replaced with a nice Kenda 90/90/18.. just like my little CG... I really hate these bicycle style front tyres you find on all Chinese bikes...
Attachment 13949
Looking smart...
Attachment 13950
You can see the handlebar position better from the rear, it's looking great!
.... okay one or two more pictures before I call it a day...
