That this motorcycle engine?
is lifan?
quality is?
In Spain have many problems.
Not working properly
http://imagenes.solostocks.com/z1_25...ol-kinroad.jpg
http://bil.cz/data/image/chopper-kin...-cyclone_0.jpg
is lifan?
quality is?
Based on a Suzuki GN250 engine. The twin ports, 2 v, single cylinder is a dead givaway, as is the distinctive 'vented' front sprocket cover. The frame is obviously a Suzuki GZ250 based.
About a million (maybe a few less) companies in China make GN125/250 type engines, and about a thousand make GZ type frames.
Sorry, exactly what were you asking?
yes, thanks
Sorry for my English
this engine is used by Kinroad
http://www.lifan.com/en/%5Cupfiles%5...5C156FMI-A.jpg
on this link http://www.mychinamoto.com/forums/showthread.php?t=521 forchetto said this:
my question is:Quote:
The top end appears to be the same as the LIFAN 156FMI-2M/162FMJ-M/163FML-2M
which is based on the OHV Honda CG125 design. They've added electric starting and balancer shaft to reduce vibration. That's what the bulge in front of the crankcase is for.
Single-cylinder,four-stroke,air-cooled,hand-clutched,electric starter/Kick starter balance shaft 125cc/150cc/200cc
Kinroad uses a Lifan engine (based on honda cg125) or a suzuki engine.
Thanks :thumbsup:
http://www.lifan.com.cn/en/%5Cupfile...C156FMI-2M.jpg
The engine in this picture is Honda based, but I don't think this is the same engine as in the first two motorcycle pictures. Come to think of it, I don't even think the first two motorcycle pictures have the same engine.
They are all different engines? :confused1:
Both engines are similar, and both are based on Suzuki designs.
If you knew the displacement, that would help.
The first bike has a GN250 style engine. Note the starter is behind the engine and that there are no chrome engine covers. It has dual exhaust (although only one exhaust valve) ports, so the top is a GN250, although the bottom might be based on a GN125.
The other engine is based on a GZ250. Note the chrome engine covers, and that the top of the cylinder is 'flat.' The engine is identical inside to a GN250, although it reportedly has more torque, less hp.
No part of either engine is remotely based on a Honda, esp not the OHV type you show.
As for not working properly, I don't know. The Chinese copies of Mikuni carbs often have the enrichment lever non functional, which will prevent starting when cold. Otherwise I will need more symptoms.
Both frames are largely identical to a Suzuki GZ series, either 125 or 250. Both are identical. The GZ250 has exhaust mounts on both sides, so more likely a GZ125 type.
The top bike has a kickstarter, which is absent on GN250's. The bottom bike probably doesn't have a kickstarter.
Yeah. Take a look at these two photos.
http://www.suzukicycles.org/photos/s..._black_500.jpg
Time to lay off the grass man! :lol8: GN250 CLEARLY has starter in front of engine. GN250 has an oil filter cap which is high on the case while the "first bike" completely lacks an oil filter cap...and probably lacks an oil filter all together. Also, take note of the distinctive engine speed sending unit and cable on the GN250's head...also totally absent on the first bike.
You sure we're looking at the same pics? :confused1:
The first picture is a Kinroad black cyclone 125/150cc motorcycle and 250cc is the second
This link can be seen:
http://www.kinroad.com/kinroad/Show.asp?ClassID=55
a friend told me he uses Lifan engine
I see that it does not
Picture of a motorcycle kinroad XT125-6
http://www.kinroad.com/kinroad/Image...1915859532.jpg
Clearly, this is motor suzuki
GN or GZ?? :confused1:
You are right. I was trying to remember based on the GZ150 I had, but I should have brought up a pic to remind of the stuff.
Sorry, the last pic in the pic is a GN125. It lacks the prominent sender wire at the top.
This is a motorcycle Kinroad Black Cyclone 125
http://img44.imageshack.us/img44/3779/kinroadmotor.jpg
is motor suzuki GN???
Sorry, I do not understand the English language :sad:
:thumbsup:
I think Kinroad uses Honda motors in Suzuki frames.
This is a picture of a Suzuki GN125. You can see the engine is different.
-GN125-
http://www.suzukicycles.org/photos/s..._black_480.jpg
thanks for everything
:thumbsup::thumbsup::thumbsup:
The engine of the photos is the engine of the honda rebel?? :confused1:
Kinroad Black Cyclone 250
http://fotos.motos.net/mnet/2009/07/.../3280628_n.jpg
http://www.todomercado.com/tm/aviso/...240_peredo.jpg
Thanks :clap:
Looks like it to me. Does it look like your Regal Raptor engine?
i have a 2008 kinroad with a 250cc moto fino motor. i talked to moto fino and he said that the 250 was an exact replica of a honda 250.Attachment 1342
i ordered a rear sprocket for a honda rebel gonna see if it will fit have a 41t goin to a 30t get some better gas mileage.
