Qlink XF/ XP 200 Needle (Jets) Change (CarbJets)
I thought I saw it on here before but could NOT Find it. I am looking for the details on Changing out the jets on the Carb - I tought someone had posted a detailed write up on this subject or am I wrong? Any advice or links, Comments, etc....Appreciated. Thanks Guys!
I Sware I saw a link before on here......Still Searching.....
Andrew :deal:
Re: Qlink XF/ XP 200 Needle (Jets) Change (CarbJets)
Here's the one I used and posted a while back;
http://www.formtechservices.com/dirt...com/Rejet.html
Please note that you do not have to remove the carb for the jet changes on your Qlink. Remove the throttle cables and loosen the screws that hold the carb to the cylinder head. You will be able to rotate the carb to access the bowel screws. Make sure that you shut the gas off first and drain the bowl.
Will do and thanks so much - Don't have to worry about gas - It hasn't had a drop in her yet! LOL
http://i182.photobucket.com/albums/x...h/DSC00396.jpg
Photo of carb showing main and pilot jet. Pilot is up the tube.
oK THANKS VINCE - NOW A STUPID QUESTION ONCE AGAIN - bUT I STAND A BETTER CHANCE ASKING THIS AND GETTING IT RIGHT THE 1ST TIME - LOL
When you put the Jets in do you screw them all the way in then back them out 3/4 turn? - I thought I read that somewhere? Sorry again for the dumb questions but better safe and done correctly.
Thanks Much
Andrew
Sorry one more - I know you must have taken the bottom off your carb several times - Did you replace the screws with Allen head bolts? if so where did you get them? I was considering getting some now, before it's to late! LOL :riding:
Just screw the jets all the way in but don't over tighten them.
I need to get some allen screws. When I rejeted my XT225 I got some screws from http://www.formtechservices.com/dirt...com/Rejet.html (also a DIY for rejecting) but have misplaced the extra ones so need to order some more.
In the mean time, I put anti seize on the screws.
Hey thanks again Vince - Much appreciated - I e-mailed the Link you sent becuase they don't have the screws listed anymore on thier webstore and I can't find any whereelse, so If you happen to find these somewhere on the web where I can purchase them shoot me a link. Thanks Once again - Andrew
If bierdo doesn't have them Jetrus does but you need to know the lenght/size http://www.jetsrus.com/parts/screws.htm
or maybe local store.
Thanks once again - Just placed the order.....:) 8)
