Motorcycle Parts names in Mandarin
Okay, so I blantantly ripped this from a Taiwanese forum (hence the traditional characters), but this is some useful stuff for all of us here in China, print it out and go point to what you need at your local shop / motorcycle market :thumbsup:
Parts
adapter 轉接座 zhuan jie zuo
air box 空氣濾清器盒 kong qi lu qing qi he
air filter 空氣濾清器 kong qi lu qing qi
alternator 交流發電機 jiao liu fa dian jī
aluminum 鋁 lü
aluminum rim 鋁框 lu kuang
axle 車輪軸心 che lun zhou xin
battery 電瓶dian ping (motorcycle/car) 電池dian chi (electronics)
bearing 陪林 pei lin
bike stand 主車架 zhu che jia (standing mount)
bolt 羅栓 luo shuan (refers to the bolts on the wheel)
bracket 束環 su huan
brake 煞車 / 剎車 sha che
brake caliper 卡鉗 ka qian
brake light 煞車燈 / 剎車燈 sha che deng
brake line 煞車油管 sha che you guan
brake pads 煞車皮 sha che pi
brake rotor 煞車碟盤 sha che die pan
bulb 燈泡 deng pao
cam shaft 凸輪軸 tu lun zhou
carburetor 化油器 hua you qi
carburetor jets 油嘴 you zui
chain 鏈條 lian tiao
choke 阻風門 zu feng men
clutch 離合器 li he qi
clutch cable 離合器線 li he qi xian
clutch pads 離合器片 li he qi pian
coil 高壓線圈 gao ya xian quan
connecting rod 曲軸柄 qu zhou bing
coolant 冷卻劑 leng que ji
crank shaft 曲軸 qu zhou
cylinder 汽缸 qi gang
drum brakes 鼓煞 gu sha (鼓式煞車) gu shi sha che
disk 碟盤 die pan
electrical tape 電器膠帶dian qi jiao dai
engine case 引擎外蓋 yin qing wai gai
engine head 汽缸頭 qi gang tou
exhaust pipe 排氣管 pai qi guan
fairings 整流罩 zheng liu zhao
front fork 前叉 qian cha
fiberglass 玻璃纖維 bo li xian wei
filter 過濾器 gùo lü qi
foot pegs 腳踏杆 jiao ta gan
frame 車台 che tai
fuel gauge 汽油表 qi you biao
fuel injection 燃油噴射 rang you pen she
fuse 保險絲 bao xian si
gas cap 油箱蓋 you xiang gai
gas line 油管 you guan
gas tank 油箱 you xiang
gasket 墊片 dian pian
gauge 表 biao
gear 檔 dang
gear lever 腳踏變速桿 jiao ta bian su gan
generator 發電機 fa dian ji
grease 黃油 huang you
handle bars 車把手 che ba shou
handle grips 手把套 shou ba tao
head light 前燈 qian deng; 頭燈 tou deng
horn 喇叭 la ba
horn button 喇叭按鈕 la ba an niu
hose 水管 shui guan
ignition 開關 kai guan
ignition button 開關按鈕 kai guan an niu
intake 岐管 qi guan
jet 噴嘴 pen zui
key 鑰匙 yao shi
kickstand 側駐 ce zhu
kickstarter 腳踏發動桿jiao ta fa dong gān
levers 拉杆 la gan
license plate 車牌 che pai
linkage 打檔杆 da dang gan
lock 鎖 suo
magnesium rim 鎂框 mei kuang
master cylinder 總泵 zong beng
metal 金屬 jin shu
mirror 後視鏡 hou shi jing or 後照鏡 hou zhao jing
muffler 滅音器 mie yin qi or 消音器 xiao ying qi
neutral light 空檔燈 kong dang deng
nut 螺絲帽 luo si mao
odometer 里程表 li cheng biao
oil 機油 ji you
oil additive 添加劑 tian jia ji
oil filter 濾油器 lü you qi機油過濾器 ji you gùo lü qi
oil gauge 機油表 ji you biao
oil pan 油底盤 you di pan
oil pump 機油泵 ji you beng
oil seal 油封 you feng
oil: blended synthetic -- 半合成機油 ban he cheng ji you
oil: petroleum-based -- 礦物油 kuang wu you
oil: synthetic 合成機油 he cheng ji you or 人造油 ren zao you
pet cock 油箱開關 you xiang kai guan
piston 活塞 huo sai
piston rings 活塞環 huo sai huan
plastic 塑膠 su jiao
pulley 普力 pu li
pulley belt 傳動皮帶 chuan dong pi dai
pully rollers 普力珠 pu li zhu
pump 幫浦 bang pu
radiator 水箱 shui xiang
radiator cap 水箱蓋 shui xiang gai
reservoir 副水箱fu shui xiang
rim 輪框 lun kuang
RPM gauge 轉速表 zhuan su biao
rubber 橡膠 xiang jiao
seal 油封 you feng
seat 坐墊 zuo dian
shell/fairing 外殼 wai ke
shocks 避震器 bi zhen qi
slicks 光頭胎 guang tou tai
spark plug 火星塞 huo xing sai
spark plug cap 火星塞蓋 hao xing sai gai
spark plug wire 火星塞導線 huo xing sai dao xian
speedometer 速度表 su du biao
spoke wheels 鋼絲框 gang si kuang
spring 彈簧 tan huang
sprocket 齒盤 chi pan
starter motor 起動機 qi dong ji 發動機 fa dong ji
stator 發電機飛輪 fa dian ji fei lun
steering damper 防甩頭 fang shuai tou
swing arm 搖臂 yao bi
tail light 尾燈 wei deng
tail pipe 尾管 wei guan
temperature gauge 溫度表 wen du biao
thermostat 水龜 shui gui
throttle 油門 you men
throttle cable 油線 you xian
throttle controller 油門座 you men zuo
tire 輪胎 lun tai
transmission gear 變速齒輪 bian su chi lun
transmission lube 傳動油 chuan dong you
transmission 變速箱 bian su xiang
triple tree 三角台 san jiao tai
turbo 渦輪 wo lun
turn signal 方向燈 fang xiang deng 轉向燈 zhuan xiang deng
valve 汽門 qi men
valve stem 輪胎氣嘴 lun tai qi zui
water pump 水泵 shui beng
washer 墊圈 dian quan, 墊片 dian pian
windscreen 擋風版 dang feng ban
windscreen(glass) 擋風玻璃 dang feng bo li
wiring harness 電線總成 dian xian zong cheng
voltage regulator 電壓調整器 dian ya tiao zheng qi
zip tie 束帶 su dai
Terms
1st gear 一檔 yi dang
2nd gear 二檔 er dang
3rd gear 三檔san dang
4th gear 四檔 si dang
5th gear 五檔 wu dang
6th gear 六檔 liu dang
2-stroke 二行程 er xing cheng
4-stroke 四行程 si xing cheng
acceleration 加速 jia su
adjust 調整 tiao zheng
burnout 燒胎 shao tai
change 換 huan
change gears 換檔 huan dang
check 檢查 jian cha
compression 壓縮 ya suo
crash (to have an accident) 車禍 che huo
crash (to hit something) 撞倒 zhuang dao
crash (to fall down) 跌倒 die dao
crash (to slide out) 甩倒 shuai dao
displacement 排氣量 pai qi liang
downshift 退檔 tui dang
drift 甩尾 shuai wei
estimate (price) 估價 gu jia
fixed 修好了 xiu hao le
horse power 馬力 ma li
idle 空轉 kong zhuan
inflate 打氣 da qi
install 安裝 an zhuang
insurance 保險 bao xian
license 駕照 jia zhao
leak 漏 lou
lean (body) 側掛 ce gua
lean (motorcycle) 壓車 ya che
loose 鬆 song
maximum speed 尾速 wei su
modify (stronger) 改裝 gai zhuang
paint 油漆 you qi
spray paint 噴漆 pen qi
stock 原產 yuan chan
take off 拿掉 na diao
registration 行照 xing zhao
RPM 轉速 zhuan su
soft 軟 ruan
stable 穩定 wen ding
start (engine) 發動 fa dong 啟動 qi dong
stiff 硬 ying
tight 緊 jĭn
torque 扭力 niu li
tune up 調節 tiao jie
wheelie 托孤輪 tuo gu lun
Riding Gear
boots 靴子 xie zi
gloves 手套 shou tao
helmet 安全帽 an quan mao
knee pads 護膝hu xi
knee pucks/sliders 滑行塊 hua xing kuai
rain gear - 雨衣 yu yi
riding gear (general) 防甩衣 fang shuai yi
suit (leather) 皮衣 pi yi
Brands
hartford 哈特佛 ha te fo (Taiwanese brand)
honda 本田 ben tian
kawasaki 川崎 chuan qi
kymco 光陽 guang yang (Taiwanese brand)
suzuki 台鈴 tai ling
sym 三陽 san yang (Taiwanese brand)
yamaha 山葉 shan ye
Types of Vehicles
Car 汽車 qi che
Big Motorcycle 重型摩托車 zhong xing mo tuo che
Motorcycle(general) 機車 ji che
Motorcycle(scooter) 摩托車 mo tuo che
Motorcycle(gear shifting) 打檔車 da dang che
Motocross 越野車 yue ye che
Scooter 速克達 su ke da
Supermoto 滑胎車 hua tai che
Re: Motorcycle Parts names in Mandarin
holy shit, serpent. this is awesome!!!
I've just had a quick look through the list and most of the terms are consistent with mainland usage, though not all. scooters here, for example, are 踏板车 tabanche.
super, super useful. I'll even save this in my gay iPhone!
cheers!
Good to see your second wife phone can be put to use ;) Yeah most people here on the mainland can understand the traditional characters anyway, so this is the sort of thing that you shouldn't leave home without :)
Super cool Serpentza,
I ran it through the converter, but can't read, so I'm not sure if it changed the characters correctly.
adapter 转接座 zhuan jie zuo
air box 空气滤清器盒 kong qi lu qing qi he
air filter 空气滤清器 kong qi lu qing qi
alternator 交流发电机 jiao liu fa dian jī
aluminum 铝 lü
aluminum rim 铝框 lu kuang
axle 车轮轴心 che lun zhou xin
battery 电瓶dian ping (motorcycle/car) 电池dian chi (electronics)
bearing 陪林 pei lin
bike stand 主车架 zhu che jia (standing mount)
bolt 罗栓 luo shuan (refers to the bolts on the wheel)
bracket 束环 su huan
brake 煞车 / 刹车 sha che
brake caliper 卡钳 ka qian
brake light 煞车灯 / 刹车灯 sha che deng
brake line 煞车油管 sha che you guan
brake pads 煞车皮 sha che pi
brake rotor 煞车碟盘 sha che die pan
bulb 灯泡 deng pao
cam shaft 凸轮轴 tu lun zhou
chain 链条 lian tiao
choke 阻风门 zu feng men
clutch 离合器 li he qi
clutch cable 离合器线 li he qi xian
clutch pads 离合器片 li he qi pian
coil 高压线圈 gao ya xian quan
connecting rod 曲轴柄 qu zhou bing
coolant 冷却剂 leng que ji
crank shaft 曲轴 qu zhou
cylinder 汽缸 qi gang
drum brakes 鼓煞 gu sha (鼓式煞车) gu shi sha che
disk 碟盘 die pan
electrical tape 电器胶带dian qi jiao dai
engine case 引擎外盖 yin qing wai gai
engine head 汽缸头 qi gang tou
exhaust pipe 排气管 pai qi guan
fiberglass 玻璃纤维 bo li xian wei
filter 过滤器 gùo lü qi
foot pegs 脚踏杆 jiao ta gan
frame 车台 che tai
fuel injection 燃油喷射 rang you pen she
fuse 保险丝 bao xian si
gas cap 油箱盖 you xiang gai
gasket 垫片 dian pian
gauge 表 biao
gear 档 dang
gear lever 脚踏变速桿 jiao ta bian su gan
generator 发电机 fa dian ji
grease 黄油 huang you
handle bars 车把手 che ba shou
head light 前灯 qian deng; 头灯 tou deng
horn 喇叭 la ba
horn button 喇叭按钮 la ba an niu
hose 水管 shui guan
ignition 开关 kai guan
ignition button 开关按钮 kai guan an niu
intake 岐管 qi guan
jet 喷嘴 pen zui
key 钥匙 yao shi
kickstand 侧驻 ce zhu
kickstarter 脚踏发动桿jiao ta fa dong gān
levers 拉杆 la gan
license plate 车牌 che pai
linkage 打档杆 da dang gan
lock 锁 suo
magnesium rim 镁框 mei kuang
master cylinder 总泵 zong beng
metal 金属 jin shu
mirror 後视镜 hou shi jing or 後照镜 hou zhao jing
muffler 灭音器 mie yin qi or 消音器 xiao ying qi
neutral light 空档灯 kong dang deng
nut 螺丝帽 luo si mao
oil 机油 ji you
oil additive 添加剂 tian jia ji
oil filter 滤油器 lü you qi机油过滤器 ji you gùo lü qi
oil gauge 机油表 ji you biao
oil pan 油底盘 you di pan
oil pump 机油泵 ji you beng
oil: blended synthetic -- 半合成机油 ban he cheng ji you
oil: petroleum-based -- 矿物油 kuang wu you
oil: synthetic 合成机油 he cheng ji you or 人造油 ren zao you
pet cock 油箱开关 you xiang kai guan
piston 活塞 huo sai
piston rings 活塞环 huo sai huan
plastic 塑胶 su jiao
pulley 普力 pu li
pulley belt 传动皮带 chuan dong pi dai
pump 帮浦 bang pu
radiator cap 水箱盖 shui xiang gai
rim 轮框 lun kuang
RPM gauge 转速表 zhuan su biao
rubber 橡胶 xiang jiao
seal 油封 you feng
seat 坐垫 zuo dian
shell/fairing 外壳 wai ke
slicks 光头胎 guang tou tai
spark plug cap 火星塞盖 hao xing sai gai
spark plug wire 火星塞导线 huo xing sai dao xian
spoke wheels 钢丝框 gang si kuang
spring 弹簧 tan huang
sprocket 齿盘 chi pan
starter motor 起动机 qi dong ji 发动机 fa dong ji
stator 发电机飞轮 fa dian ji fei lun
steering damper 防甩头 fang shuai tou
swing arm 摇臂 yao bi
tail light 尾灯 wei deng
temperature gauge 温度表 wen du biao
thermostat 水龟 shui gui
throttle 油门 you men
throttle cable 油线 you xian
throttle controller 油门座 you men zuo
tire 轮胎 lun tai
transmission gear 变速齿轮 bian su chi lun
transmission lube 传动油 chuan dong you
transmission 变速箱 bian su xiang
triple tree 叁角台 san jiao tai
turbo 涡轮 wo lun
turn signal 方向灯 fang xiang deng 转向灯 zhuan xiang deng
valve 汽门 qi men
valve stem 轮胎气嘴 lun tai qi zui
washer 垫圈 dian quan, 垫片 dian pian
windscreen 挡风版 dang feng ban
windscreen(glass) 挡风玻璃 dang feng bo li
wiring harness 电线总成 dian xian zong cheng
voltage regulator 电压调整器 dian ya tiao zheng qi
zip tie 束带 su dai
Terms
1st gear 一档 yi dang
2nd gear 二档 er dang
3rd gear 叁档san dang
4th gear 四档 si dang
5th gear 五档 wu dang
6th gear 六档 liu dang
adjust 调整 tiao zheng
burnout 烧胎 shao tai
change 换 huan
change gears 换档 huan dang
check 检查 jian cha
compression 压缩 ya suo
crash (to have an accident) 车祸 che huo
displacement 排气量 pai qi liang
downshift 退档 tui dang
drift 甩尾 shuai wei
estimate (price) 估价 gu jia
horse power 马力 ma li
idle 空转 kong zhuan
inflate 打气 da qi
install 安装 an zhuang
insurance 保险 bao xian
license 驾照 jia zhao
leak 漏 lou
lean (body) 侧掛 ce gua
lean (motorcycle) 压车 ya che
loose 松 song
modify (stronger) 改装 gai zhuang
paint 油漆 you qi
spray paint 喷漆 pen qi
stock 原产 yuan chan
take off 拿掉 na diao
RPM 转速 zhuan su
soft 软 ruan
stable 稳定 wen ding
start (engine) 发动 fa dong 启动 qi dong
stiff 硬 ying
tight 紧 jĭn
torque 扭力 niu li
tune up 调节 tiao jie
wheelie 托孤轮 tuo gu lun
Riding Gear
boots 靴子 xie zi
gloves 手套 shou tao
knee pads 护膝hu xi
knee pucks/sliders 滑行块 hua xing kuai
Brands
honda 本田 ben tian
kymco 光阳 guang yang (Taiwanese brand)
suzuki 台铃 tai ling
sym 叁阳 san yang (Taiwanese brand)
yamaha 山叶 shan ye
Types of Vehicles
Car 汽车 qi che
Big Motorcycle 重型摩托车 zhong xing mo tuo che
Motorcycle(general) 机车 ji che
Motorcycle(scooter) 摩托车 mo tuo che
Motorcycle(gear shifting) 打档车 da dang che
Motocross 越野车 yue ye che
Scooter 速克达 su ke da
Supermoto 滑胎车 hua tai che
Definitely putting this on my "not as gay as an iPhone" Android device.
Most native Souther are brainwashed by HK / TW tv that still reads traditional BUT migrant mechanic are the "majority".
Some TW term above = :bs: if use in mainland. ALMOST completed. :clap: Pls don't ask the Pinyin, I can't master it yet. My Mandarin is passable ONLY.
Parts
adapter 转插
air box 空滤盒
air filter 空滤
alternator 磁电机
aluminum 铝
aluminum rim 铝轮圈
axle 车轴
battery 电瓶 (motorcycle/car) 电池 (electronics)
bearing 轴承
bike stand 大撑 (standing mount)
bolt 螺栓 / 杆 (refers to the bolts on the wheel)
bracket 卡箍
brake 刹车/ 制动
brake caliper 卡钳/ 下泵
brake light 刹车灯
brake line 刹车/ 制动油管
brake pads 刹车片
brake rotor 刹车碟/ 盘
bulb 灯泡
cam shaft 凸轮轴
carburetor 化油器
carburetor jets 油咀/ 三角针
chain 链条
choke 阻风门
clutch 离合器
clutch cable 离合线
clutch pads 离合片 ( friction part : 木片 | metal part: 铁片 )
coil 高压包 / 点火线圈
connecting rod 连杆
coolant 冷却液
crank shaft 曲轴
cylinder 汽缸
drum brakes 鼓刹
disk 碟盘
electrical tape 电工胶布
engine case 发动机箱体
engine head 缸头
exhaust pipe 排气管
fairings 外壳/ 罩
front fork 前叉
fiberglass 玻纤/ 玻璃钢
filter 过滤器
foot pegs 脚踏
frame 车架
fuel gauge 油表
fuel injection 燃油喷射 (EFI 电喷 are more common term)
fuse 保险 (管/ 丝)
gas cap 油箱盖
gas line 油管
gas tank 油箱
gasket 垫片
gauge 表
gear 档
gear lever 变档杆
generator 发电机
grease 黄油
handle bars 方向把
handle grips 把套
head light 头灯
horn 喇叭
horn button 喇叭按钮
hose 软管
ignition 点火
ignition button 点火按钮
intake 进气管
jet 喷咀
key 钥匙
kickstand 边撑
kickstarter 启动杆/ 打火棍
levers 牛角
license plate 车牌
lock 锁
magnesium rim 镁轮圈
master cylinder 上泵 /总泵
metal 金属
mirror 后视镜
muffler 消声器
neutral light 空档灯
nut 螺丝帽
odometer 里程表
oil 机油
oil additive 机油添加剂
oil filter 油滤
oil gauge 机油表
oil pan 油底壳
oil pump 机油泵
oil seal 油封
oil: (Fully 全) synthetic 合成机油
petcock 油箱开关
piston 活塞
piston rings 活塞环
plastic 塑胶
pulley 皮带轮
pulley belt 传动皮带
pully rollers 普利珠/ 离合珠
pump 泵
radiator 水箱
radiator cap 水箱盖
reservoir 副水箱
rim 轮圈
RPM gauge 转速表
rubber 橡胶
seal 油封
seat 坐垫
shell/fairing 外壳
shocks 减震
slicks 无纹热熔胎
spark plug 火花塞/ 火咀
spark plug cap 高压帽/ 火咀帽
spark plug wire 点火线
speedometer 速度表
spoke wheels 輻條轮圈
spring 弹簧
sprocket 链轮/ 齿盘
starter motor 起动马达
stator 定子
steering damper 防甩头/ 扭力杆
swing arm 摇臂
tail light 尾灯
tail pipe (排气) 尾段
thermostat 节温器
throttle 油门
throttle cable 油门线
tire 轮胎
transmission 变速箱
triple tree (上/下) 联板,三星
turbo 涡轮
turn signal 转向灯
valve 汽门
valve stem 轮胎气咀
water pump 水泵
washer 垫圈/片
windscreen 挡风板
windscreen (glass) 挡风玻璃
wiring harness 电线总成
voltage regulator 整流器
zip tie 札带...
Terms
1st gear 1档
2nd gear 2档
3rd gear 3档
4th gear 4档
5th gear 5档
6th gear 6档
2-stroke 二冲程
4-stroke 四冲程
acceleration 加速
adjust 调整
burnout 烧胎
change 换
change gears 换档
check 检查
compression 压缩
crash (to have an accident) 事故
crash (to fall down) 倒下
displacement 排气量
downshift 退档
drift 甩尾
estimate (price) 估 (价)
fixed 修好了
horse power 马力
idle 空转
inflate 充气
install 安装
insurance 保险
license 驾证
leak 漏
lean (body) 侧掛
loose 松
maximum speed 极速
paint 油漆
spray paint 喷漆
stock 原装
take off 拿掉
registration ***:deal: PRC gov had many types of docs about ur bike BUT d/l + Vehicle License 行驶证 is a MUST to ride it on public highway***
RPM 转速
soft 软
stable 稳定
start (engine) 启动
stiff 硬
tight 紧
torque 扭力
tune up 调校
wheelie 独轮/ 翘头
Riding Gear
boots 靴
gloves 手套
helmet 头盔
knee pads 护膝
knee pucks/sliders 磨包 /滑行块
rain gear 雨衣
riding gear (general) 防摔衣
suit (leather) 皮衣
Brands
hartford 哈特佛(Taiwanese brand)
honda 本田
kawasaki 川崎
kymco 光阳 (Taiwanese brand)
suzuki 铃木
sym 三阳 (Taiwanese brand)
yamaha 雅马哈
Types of Vehicles
Car 汽车
Big Motorcycle 大排
Motorcycle(general) 摩托车
Motorcycle (e.g naked bike ... ) 骑式车/ 男装车
Motocross 越野车
Supermoto 滑胎车
Motorcycle(e.g scooter) 坐式车 / 女装车
Scooter 踏板车
Excellent :) Android.. the OS for those who aren't paid for sex ;)
@humanbeing.. they still learn traditional in the KTVs when singing the Taiwanese and Cantonese songs ;)
ChinaV, your converter renders it all into simplified chinese, but does nothing to adapt to mainland USAGE -- which can be quite different from Ta*wan/HK usage. We're talking actual vocabulary differences like bonnet/hood, lorry/truck, etc, rather than just spelling differences like armour/armor. I very much look forward to humanbeing's mainlandification.
cheers!
My Chinese isn't half bad, and most of those terms are correct, there are only a few small differences, and they may laugh at you but still understand :)
I recently went with RichardKTM and a few other blokes to the Guangzhou bike market and we struggled like hell to find a new air filter because we didn't know how to say it, eventually we figured it out through a lot of trail and error.. and sure enough it's a air filter 空氣濾清器 kong qi lu qing qi, so I think this list should work in most cases :)
Serpentza
@humanbeing.. they still learn traditional in the KTVs when singing the Taiwanese...
:eekers: Pronunciation from "those" KTV girl are HORRIBLE. They can't sung "深" in TWese song. "心" is correct term in "those" place :lol8:
EXCELLENT POST! Just to add one term i didn't see in the list, which is useful for us CJ riders:
Reverse gear 倒档 dao dang
For the ones with funny engines:
Valve Adjustment Shim - 气门调整垫片
:confused1: Can anybody of the literate confirm. :rolleyes1:
How about oil drain plug?
How about magnetic oil drain plug? I'm trying to look for one on Taobao, anyone bought one of those before?
Standard oil drain plug is 放油螺塞 (fangyouluosai release oil screw plug).
magnetic is 磁性 (cixing).
hence...
http://item.taobao.com/item.htm?id=8906834299
Good idea about the magnetic drain plug! Ton's more here:
http://s.taobao.com/search?q=%B4%C5+%B7%C5%D3%CD
Carburetor Assembly 化油器总成 Huà yóu qì zǒng chéng
Guide,Intake Valve 进气门导管 Jìn qìmén dǎoguǎn
Guide,Exhaust Valve 排气门导管 Pái qìmén dǎoguǎn
Cylinder Block 气缸体组合 Qìgāng tǐ zǔhé
Gasket, Cylinder Block 气缸体密封垫 Qìgāng tǐ mìfēng diàn
Cylinder Head 气缸头组合 Qìgāng tóu zǔhé
Gasket, Cylinder Head气缸头密封垫 Qìgāng tóu mìfēng diàn
Cover,Cylinder Head 气缸头盖 Qìgāng tóu gài
Sealing Ring 气缸头盖 Qìgāng tóu gài
Intake Pipe Set 进气管组合 Jìn qìguǎn zǔhé
MC_D250RTC Parts List
The drain plug on our Jialing JH600 is described in the manual as M14x12. Does the 12 mean it's 12mm in length? The only magnetic M14 plug I've found subsequent to Felix's post is this one, described as M14x1.5. As you can see (if you click on the link) it has a protuberance that presumably extends 3mm deeper into the case. How would one check whether there is sufficient clearance to use this plug?
http://item.taobao.com/item.htm?id=7574878271
Thanks!
MJH
I suppose we lost the memo that English is the international business language? Seriously do not copy us if you cannot speak the fucking language. Ketchup is something that goes on a hot dog or hamburger and to dip French fries in…catch up is what you fetching need to do….chop chop.
Dear MJH, would you mind please translating your post into a language I can understand? I read English and Chinese.
thanks!
http://www.engineersedge.com/hardwar...ead-sizes1.htm
Here's a chart with bolt sizes in metric. I suppose you can check if there's enough clearance if you stick your finger in. But 3mm? Of course there's enough clearance for 3mm. It's not bolted against a flat surface. At least it's clear from most motorcycles I've seen.
What's up with MJH? He's all over the forum with similar posts today ??!!
MJH you are a valued member here and probably no more insane than any of the rest of us. However today some of your posts are offensive or at least very much on the edge as you are no doubt very aware.
Please check yourself over and try and calm down or whatever you usually do to rein yourself in. If it is meds then take one, if it is anger or hurt for something off forum then PM me and I will happily talk, even on phone.
If you are just trying to be a bastard like me then you are failing, not pulling it off. Relax man.
Thanks for this Serpentza, my Chinese teacher doesn't even know most of these terms. Much appreciated.
Years ago I had what was called a "functional reference dictionary" that had pictures of all kinds of devices and situations, with Chinese and English equivalents for all the relevant items. One was for a bicycle, with obvious stuff like pedals, handlebars, spokes and nipples, but also more technical terms like bottom bracket, headset, derailleur, etc. Lost in the mists of time, and would love to find another, but this live list in MCM is 100 times better....
now thinking about how we can capture it all in one place. is there a wikipedia site where stuff like this can be parked and constantly updated?
...The drain plug on our Jialing JH600 is described in the manual as M14x12. Does the 12 mean it's 12mm in length? The only magnetic M14 plug I've found subsequent to Felix's post is this one, described as M14x1.5...
The "ghetto" DiY = "AB Glue" Neodymium magnet (钕铁硼磁铁) in plug head
humanbeing
HB, you saying the magnet is glued into the plug? Meaning what? that it might come loose? This plug looks a lot like the plugs our bobber boys have bought recently. Is it not wise to use one?
thanks
HB's just saying, glue a magnet to the head of the plug and save buying one. Good idea, I shall do it, got lots of magnets.
The "ghetto" DIY = glued into "head" (i.e. outside) BUT chinese road had tons iron ??? (Y1 coin ...)
The "commercial" version (i.e. inside) is FAR better.
Crack open a computer hard drive, its got two strong magnets inside. I'll do this before I change the plug next oil change.
OP keeps updating the first post and this will be make the thread a sticky?
Why not indeed! Now a 'sticky' unless boss overrides. Good idea Slabo, thanks - so now it is easily findable. Any one can add to it because we have peer review by native Chinese speakers and experienced 'bi-linguals'. A bit of 'off-topic' doesn't hurt so long as the main theme is understandable.
Terminology tables that have translations, if you had a database with parts then you would link to one of those translation tables and select a description from a list, subsequently that would allow viewing a parts directory in every language.
Then assign it a part number and associate it with a specific make and model, coded to a schematic, which would be located in a table of diagrams.
One person enters the data, another validates that data and then still a third person, then it get loaded into a system of tables.
Item;Language;term
1; Chinese;火花塞
1; french;bougie
1; German;Zündkerze
Item; English name
1;spark plug
