putting a 250cc in a 125cc Sinnis Apache/ pulse adrenaline / superbyke rmr125
Ok so im getting a Sinnis Apache 125cc soon.
Once i do my test and what not, is there a 250cc engine that i am abel to slap in there.
The engine is a cg125 copy and there are cg250's out there would that work
Re: putting a 250cc in a 125cc Sinnis Apache/ pulse adrenaline / superbyke rmr125
the sinnis apache uses a Suzuki GN-125 engine not a CG125
Kennon
I think that they are the same - right
any way is there a 250 engine out there to slap in to my bike
a cg125 engine is from a honda just look at a comparison of the two engines the suzuki engine produces abit more power than that of the CG125
you can make any 250cc engine fit its just how good you are with frame modifications
Kennon
ok me doing anything like modding a frame is like your great nan using a computer.
aha nice to know well the key part of fitting a bigger engine is does the head clear the bottom of the fuel tank is there space for it, how heavy and what affect it will have on the strength of the frame, most crutial part is the engine mounts being perfectly centered or you'll be going through chains and sprockets quicker than fuel
well i have found out that Sinnis are brining out a 250 version of the apache, so hopefully i will just be able to buy one of those and slap it in there. from looking at the pics of the engine your right they are just a copy of the gn125 hope fully will be the same for the 250
the frame is slightly different in the 250cc version
Kennon
how do you know that it is diffrent
Also in my last topic you said you had the manual for the gn 125 - thats great how can you get than to me thanks again
just send me a private message with your E-mail and i can send it to you
How do you know that the 250 is diffrent
this idea has already been though about its a different engine the 250 is a TU250 engine its heavvier and mounts differently hence why its held differently compared to the 125 or 200cc engine
hummm problem. think i will get a 200 and a big bore do you know where i can get both of them from
ya they have not got a 200cc engine on that site
I have, they only sell parts for the engine and not as a whole
the 200cc and the 125 share the same bottom end all that is essentially different is the cylinder, cylinder head, piston and carb this job has already been done before by some guy in portugal but with the 150cc head
