Electrical Probs with QingQi 200...
Hey everyone,
I curently seem to be having an electrical problem with my bike, very strange. At first the starter failed, or the starter button, or the solinoid, or the battery, not sure. I noticed it killed the lights and everything. I wiggled a couple wires and the lights lit up. I pushed the starter button and this time it just clicked and everything went dead again. I played with more wires and the lights came on again, tried the starter button and it didnt make a sound, and of course eaverything went dead. So after looking at it for a few minutes I turned the key and everything came on. So then I just kick started it and rode home.The next day, I kick started it, and the engine will start and idle, but will not rev up at all. When I turn the throttle it just coughs and sputters. When I turn on the ignition with the key, the headlight takes five or ten seconds to light up but is very very dim. When I start the engine it does not get brighter like you thing it would. However, and this is the strange thing about it, when the bike is running, I can pull and hold the front brake lever and the engine will rev. This will also happen if hold the headlight flasher on. Now I have disconnected the battery completly and started it and same thing, will not rev. Now it could be two different things wrong between the starter and the engine not revving. Could be coincidence. The engine not revving sounds like an ignition problem, stater, cdi box, ignition coil, even loose plug wire, who knows.(except for the plug wire, I checked that, duhh) But after some time of checking wires for shorts or being loose, I can turn on the key and all the lights come right on and the bike kickstarts and runs just fine. But then shut off and turn the ignition back on and it does the same thing, light wont come on right away and engine will start but not rev, this has repeated itself a few times after looking for problems. Now, I am a very good mechanic when it comes to the engine. I can tear it down and rebuild it like nothing. Ive been doing this with my dirt bikes for years, two stroke, four stroke, it doesnt matter, but electrical sucks. I did read what forchetto said about the regulater, it could be that. I have a voltage meter, does anyone know if you can test the regulater with one. I would also like to know if ChinaV had any symtoms other than the battery not holding a charge
Any suggestions, thanx.
Qingqi QM200GY-BA battery area wiring
MotoDrunken
I should take care of a multi-wire connector that resides above and to the right of the battery, next to the chassis, one that has a rubber holder that fastens to a small bracket by pushing it. My friend told me that I will most certainly find it installed in such a way that it would allow to get water in
The item you mention that is held by a chassis tab is the winker relay. There's a bunch of wires with a connector further up, but is well protected from water thrown by the wheel.
The thing to check is the tightness of starter relay connection posts and specially the main engine earth cable. This cable is responsible for all current out of the generator and all current into the starter motor. Any resistance there will make things funny.
The following pictures show this cable, at the chassis end and at the engine end. The main battery earth cable also has to be tight.
http://www.telecable.es/personales/a...atteryarea.jpg
http://www.telecable.es/personales/a...ngineearth.jpg
Re: Qingqi QM200GY-BA battery area wiring
forchetto
Hi forchetto... i need your help, maybe you can help me to solve my problem. The problem is when the battery weak or damage, i cannot start my engine using the lever kick start like in the picture below. So what you think? Anybody also can help is they know how to solve this problem.Thank you!!!
Attachment 7751
Hi Hescort and welcome to MCM!
My best bet would be to check the rectifier/regulator. That might be burnt and might need a replacement. If the R/R works ok, your battery'll get charger and you'll forget about kickstarting your bike.
Qingqi's motor should start regardless of the state of battery. Just kick start it properly or simply try to push start him in second gear.
Re: Electrical Probs with QingQi 200...
http://www.triumphrat.net/members/44601-forchetto.html
if you looking for him....
Based on the information I would guess maybe a dead battery and flooded carburetor? Can you ever kick start the bike or do you only attempt to kick start it after multiple failed attempts with the electric ignition? Is the ignition clicking or is it going rrrrr? The first is a dead battery the later is fuel not enough or too much of it.
My bike is very difficult to kickstart when the battery is dead and will flood easily, when my battry is good, it kickstarts with ease. In reference to my original post at the top of this thread, I replaced the battery with a new one and the problem was solved. (The original battery went deffective after a few months.)
In response to Hescort's post, I have been kickstarting my bike recently with the battery pretty much dead. The lights come on when I turn on the ignition but are dim, and the electric starter will not turn over at all, the solinoid wont even click. A few days ago I kickstarted it and it began to sputter when I reved the engine, it went away after it warmed up. The next day it began to sputter when riding to work. So, I recognized these symtoms when I had the problem with the original battery. I replaced the battery yesterday with a new one, and problem solved. For whatever reason, the bike will not kickstart properly or run properly when the battery is dead.
