Tourfella panniers - Upholstering
I'm planning to upholster the inside of my Tourfella panniers. My idea is to use felt for this, not totally sure about what would be the best way to make it stick. First thing I could think of was double-sided tape, any other ideas/experience on this?
Barry
Re: Tourfella panniers - Upholstering
G'Day,
B&Q -The Hardware Store- has this thin black rubber "carpet" (sold by length of a large roll in B&Q Shanghai) and works great with good quality double sided tape.
Using the rubber "carpet" for my tool cabinets and shelf, no problems, easy to keep clean and looks neat.
While in B&Q look for some sprayable glue - There should be something from Patex or Loctide, excellent stuff to glue bigger areas
Thanks, for your input guys.
What about sun/heat from the exhaust pipe, could they make the double sided tape come off?
Hey Barry - This carbon-fiber adhesive may work for you.
Attachment 6814
Nice lining
Inexpensive
Adhesive
Looks cool
You can buy it on Taobao here.
I'd like something more shock-absorbing for covering the inside. Not the fluffy hairy stuff chinese like to put on their car seats and steering wheel of course!
Thinking of this!
I used some stuff that is anti-slip and kind of soft rubber, 3-5mm thickness, it was left over in our electronics manufacturing/assembly.
Any contacts into the elctronics assembly? Check with them.
I wouldn't use felt. It is very difficult to clean once it got wet, dusty or otherwise dirty.
I was thinking about neoprene but then turned to ordinary soft wall covers, the ones you would use instead of ceramic tiles in a bathroom or kitchen. Glue them with carpet glue all along the edges and a dot or two on the rest of the area.
Easy to wet-clean, cheap n easy to install, good to remove. Should be available in B&Q or construction material markets.
Hi Barry:
I mistakenly did this with a set of aluminum panniers I had back home. Moisture/dirt got trapped and it began to corrode/deteriorate the aluminum (turning into that white powdery stuff).
Nevertheless, if you're keen on it ... you can check out the Muxiyuan materials market in Beijing. It has everything you could possibly imagine, including Russian Sable (complete with heads). Go to Google Maps, and type in 39.85403,116.402096 ... it is just behind the mobile phone market on the S 3rd ring road, along the road that heads SE from the bridge. The market is several blocks long, and is about a block deep on each side. If you can't find a material here, it doesn't exist.
One better option, IMHO, are pannier inserts made from a tough, cloth material. They are handy because they provide some shock absorption, but also have handles to make it easy to lift the bags out and take into a hotel. Tourfella used to make them, but apparently no longer does. But if you left a pannier with one of the materials shops in the market, the shop could easily custom-make some. You'd just need to decide what material you would like the bag made out of.
Wish you every success ... and then I can copy it!
Lao Jia Hou
...One better option, IMHO, are pannier inserts made from a tough, cloth material. They are handy because they provide some shock absorption, but also have handles to make it easy to lift the bags out and take into a hotel. Tourfella used to make them, but apparently no longer does. But if you left a pannier with one of the materials shops in the market, the shop could easily custom-make some. You'd just need to decide what material you would like the bag made out of.
Here is the perfectly fitted insert with carrying straps, but these were not made by Du Rui at Tourfella, despite the branding. Rather, the ever-inventive Pfaelzer had them made through his sourcing network, presumably in Fujian. Pictures from Pfaelzer's epic JH600 thread. I have a set of these and love them. It's easy to keep the panniers clean inside, which might not be the case if you upholstered the interior surfaces.
cheers!
http://pfaelzer.smugmug.com/Motorcyc...95_dswMr-L.jpg
http://pfaelzer.smugmug.com/Motorcyc...09_24LKZ-L.jpg
Yup - that's the ticket. Probably made out of Cordura, like the stuff back packs are made from. I've seen this material in the market. You could probably print out these pics and take them to a shop to custom-make something.
Thanks Euphonius, obviously I'm aware of those bags. One of my favorite threads so :mwink:
Don't your bags wear off at certain locations, due to parts slightly sticking out inside the panniers?
Barry
Actually, I've not used them excessively, as I've been in non-rider mode for more than a year due to an injury. There is some friction when you take them in and out of the panniers, and the main points of friction, as you've correctly surmised, are the screw plates that hold the panniers to the frame. Just try not to cram them too full. Or perhaps install a smooth and semirigid/flexible cover over the screw plates to isolate them from the bags.
Hey guys, listen, I need to pickup on this old thread pertaining to Tourfella panniers. Currently on Taobao there are many copycat variations on the Tourfella boxes. I am outfitting my new GW250 with boxes and wanted to buy the black tourfella or the best clone. Any input on the "Sevens" and others like them? Are they in fact clones or just Tourfella "version 2"? Regardless, I could use input on recent purchases of all similar aluminum types (specifically black to go on the black bike. I am looking for the smaller volume sizes (maybe 32L) as I want to keep the weight down and I am just looking to take weekend trips in surrounding Beijing hills and mountains.
