Lao Jia Hou
Thanks Chinabiker - your explanations help.
Perhaps my misunderstanding was that I assumed electrical power was constantly being produced by the generator.
For example, when you start the vehicle, the generator is producing (let's say, for example) 100 Watts at idle RPM (e.g., 1,000 rpm). This electrical power is routed to whatever devices need it (e.g,. primary ignition, fuel pump, electronic gauges, sensors, etc.). Often, however, there is insufficient electrical generation, at idle, to also top up the battery, so there is often little battery charging happening. Everything that is being produced at idle speed is being consumed by the basic (mandatory) electrical devices.
As you increase RPM, the generator spins faster, and this increases electrical power generation. As an example, perhaps at 3,000 RPM, the generator is now producing its maximum capability (e.g., 300 Watts). But perhaps you do not have any optional, electrical accessories turned on (e.g., lights, heated grips, etc), so the extra power generation is routed to battery charging. If your battery is fully charged, the system dumps the excess electricity to ground.
If your generator is producing its maximum output (e.g., 300 Watts) at 3,000 RPM, and you start turning on accessories (lights, heated grips, etc), the generator will "fund" the requirements up to the maximum of 300 Watts. If you turn on enough accessories (e.g., 400 Watts) to go over the generator's capacity, the extra requirements of 100 Watts is "funded" from the battery. Eventually, you run down the battery.
Chinabiker, you explain that power production is not done until there is a load - for example, you turn on the lights, effectively closing a circuit thereby creating a drag on the generator due to an increase in the magnetic field through which the windings travel, albeit the "drag" would be infinitesimally small. That would be possible, and makes sense.
I thought, however, that modern electrical systems (i.e., post 1960s) were designed so that the generators were always producing the maximum output, dependent upon RPM, and dumping excess production (i.e., sending it to ground). Maybe I'm wrong. Again.
