Pulse Adrenaline wiring loom
Ok so I have my finally taken delivery of my Pulse adrenaline now.
Took it out for a couple of spins and everything was fine, bit of bother getting it started but just put that down to the bike not being used, so battery possibly dying.
When I turn the ignition on all the lights and indicators work but when you hit the ignition switch the battery just clicks away as if its just not got enough power to turn over.
Got a hold of a charger and started charging it, long story short 2 days charging and it still wont turn over now. So while the seat was off I took the opportunity to have a look at the wiring. I now wish I had remained blissfully unaware of it!!!:eekers: Its a mess, I think there is more insulation tape than wires!
The wires that are there are all badly corroded and in some cases even melted! Some of them dont even connect to anything?!
So ive bit the bullet and ordered the owners manual and a new wiring loom.
My question (eventually!) is does the owners manual come with a wiring diagram or am I just going to have to go into this and work it out for myself? Has anybody had any experience of having to do this kind of thing?
Re: Pulse Adrenaline wiring loom
Brad
Just refer to bigger brother's manual http://www.mychinamoto.com/forums/showthread.php?2565 for wiring diagram.
It should be easy enough to fit, due to the simplicity of these bikes there aren't many electrical connections compared to a wiring loom of a car. Just figure out which way round it goes, route it through the bike as the old one was, connect everything up and you're done.
Humanbeing;
Thank you for that link, the manual it contained was a million times more detailed than the crappy one I just bought for the adrenaline!!
Spencer;
Its taken me about half an hour to figure out which way round it goes as there was so much muck and crap, previous owner really did a number on these wires! Ive managed to work out a few of the connections but some of the wires it looks like hes replaced with any old wires hes had laying about his garage! I'll persevere though might take me a while but i'll get there! Any recommendations on a new battery? Should i just order one through the chinese spares site or am i better off going along to halfords or something?
In addition to a wiring diagram a multimeter would be of use so you can match up both ends of a connector with the continuity function. As for a new battery I have just ordered one from eBay for £22, it seems to be made by a good name brand and it's twice the capacity of your standard battery so your bike will start easier and there will be less chance of it going flat. If you get it from Halfords it will cost almost double.
http://www.ebay.co.uk/itm/1907072595...84.m1439.l2649
Okay time for an update.
Bike works a bloody treat now! Took me about an hour to install the new wiring loom, the old one was a complete mess. Im pretty sure there must have been a short somewhere in the wires, the fuse was still good but just too many corroded wires and wires that went nowhere!
However that being said im still left with 2 wires that dont connect to anything, I think they might be for the side stand switch but upon further inspection it doesnt seem to have one on the bike?!
But that being said I took a deep breath, hit the ignition and jackpot...... started first time! Even the battery seems to be fine!
Replacing the wiring look might have been overkill but at least I know everything is connected and everything now works!
Spencer;
A multimeter is going to be my next purchase think it could prove invaluable when something goes wrong!
Humanbeing;
That link you gave me to the manual proved to be a Godsend!
Thanks to all for your help, any of you guys ever up in Edinburgh the beers are on me!
Good to hear that you got it sorted. This is just a guess but the 2 left over wires could be ground wires that are supposed to be attached to the frame or engine, you may be able to figure it out when you get your multimeter
I thought that too but they are connectors that something is meant to plug into? Though ive just noticed that my rear indicators dont work?! Even though they are connected according the diagram and the bulbs arent blown as that was the first thing I checked?
Prehaps the 2 wires are supposed to be connected to the indicator relay. On my bike the 2 wires are black and green with an L shaped connector, the indicator relay may be next to the battery.
Hi Brad
Noticed your post and that you're local to me. I'm just outside Edinburgh in E Lothian, and due to a job change coming up in a few weeks, will be commuting across Edinburgh daily instead of down to the Borders. Perfect reason to flog the car and buy a 125 for fun commutes and bombing around town, save some dough, and we'll be a one-car family which the missus will use 99% of the time.
Had a couple of bigger bikes in the past, but got fed up of paying too much at dealers to maintain them (who did a crap job as well), risking my licence too many times, and risking my life too many times as well ;)
Just wondered if you ever got your Pulse Adrenaline up and running properly? Wanted to know what your opinion of the Adrenaline was? Is it worth me buying one? I have looked at a few used Japan motards, but am wondering whether used Jap offers anything more than new Chinese.
Many thanks
Japanzzz
You should buy a Sinnis Apache instead as they have much better build quality all round, the Pulse Adrenaline is just a cheap copy of the Apache.
The Adrenaline and Apache are both from Qingqi and as far as I'm aware the difference is just the plastics. The New adrenalines have stainless steal exhausts and lithium ion batteries which the sinnis doesn't so both have pros and cons.
BTW the Adrenaline does have a side stand switch so looks like yours has been ditched.
I'm pretty sure it's the wiring on all Chinese bikes that are more insulation tape than wiring as I have the same on my venture xt3 125!
