5 Attachment(s)
Benelli QianJiang 600GSA for release May 2014
Attachment 15023
Specifications
Twin up/down halogen headlights with lower projector lamp, LED indicators & tail/brake light, CDI, electric start.
Length: 2150mm, height: 1280mm (excl: mirrors), wheelbase 1430mm, width: 800mm (excl: mirrors), ground clearance: 150mm, rider seat height: 800mm, pillion seat height: 940mm, unladen weight: 223kg, laden weight: 243kg, fuel tank capacity 27L (including reserve 3L).
Front aluminium alloy wheel: 3.50×17 MT 120x70R17
Rear aluminium alloy wheel: 5.50x17 MT 180x55R17
Front hydraulic double floating disc brake with 4 radial piston calipers: 320mm
Rear hydraulic single disc twin piston caliper brake: 260mm |
| Engine: Wet sump, 600cc liquid-cooled DOHC, 4-valve/cylinder fuel-injected - 4 throttle bodies ø38mm in-line four cylinder; 60kW (82bhp) at 11000rpm; 55Nm at 8000rpm. Compression ratio: 11.5:1. Bore x stroke: 11.5:1. Ignition: Delphi MT05, Spark plug: NGK CR9E. Euro3 catalytic exhaust with 4 O2 sensors. |
Transmission: Wet clutch, 6-speed sequential gearbox (1-down, 5-up), chain final drive. Primary drive: 44/82, Chain drive ratio: 14:46.
Gear ratios:
1° – 13/37
2° - 19/37
3° - 18/28
4° - 24/32
5° - 21/25
6° - 24/26 |
| Frame: front steel trestle with rear aluminium alloy casting frame; Ø50mm USD front forks with 120mm stroke; rear monoshock adjustable for spring preload & rebound dampening with 123mm stroke. Rear alloy swingarm. |
| MSRP: 元49800. |
| Hot: Looks like it is worth more than the MSRP; has most of the basics sorted; comes complete with integrated lockable removable panniers, luggage rack with removable SHAD top box. |
| Not: no center stand, panniers & SHAD top box are un-lined, no ABS brakes on the mainland PRC model (though ABS is offered in other international markets!). |
I'd posted this in the Manufacturers Info but wasn't able to attach photos, so am reposting here complete with photos.
Yan Haimei, CEO QJ Benelli plans and statement can be found here.
Benelli BN600GT (BJ600GSA) is slated for release 27 May 2014 in PRC according to phone conversation with the Qianjiang Benelli factory based in Taizhou, Zhejiang province today (21 March, 2014). Pre-bookings deposits are being accepted at some Benelli dealers within the mainland. As of late April some dealerships have taken early delivery of the BN600GT aka BJ600GS-A.
Attachment 15025
QJ/Benelli advises that there will be two versions of the BN600GT adventure model. One version made in PRC will be exclusive to the domestic market, while the second version is intended for the international/global markets excluding PRC. The second/latter version will be assembled offshore from parts supplied by the Benelli Qianjiang PRC factory although no word, if any parts, for the upgraded model with [better quality] parts will be sourced from other suppliers.
Attachment 15027
One of the significant differences between the two versions is that the domestic market model will not be fitted with ABS, while the international destined version will. Other differences include upgraded suspension and brake components (conjecture on my part) as had occurred with the BN600GS or renamed BN600R model where the international model came with substantially upgraded brake and suspension components over the domestically available model.
Attachment 15029
BN600GT MSRP CNY 49800.
Attachment 15030
上海锋驰 贝纳利 巡航版黄龙600 BJ600GS-A,全国首发 接受预定
BN600GT 旅 行新伴侣——贝纳利欧洲本次全球首展了其最新力作,裸版BN600R的新运动旅行版本2014年新Bene nlli BN600GT,受到格外关注,造形 曲线柔和、驾乘方便舒适、多功能及经济性使得它能轻松成为多数骑士摩托旅途的新伴侣。它是和BN600R悬 挂相同600cc直列四缸发动机的新车。车架跟 BN600R设计一样的钢网格与铝板,但BN600GT采用了一个不同的香蕉形摇臂,使GT版的单悬排气相 比R版的双排气要节省些空间。整流罩和挡风玻璃 提供风保护和更直立的座椅位置,让BN600GT更适合巡航旅行骑行。整片式座椅带有凸起的后座,更舒适的 把手取代了BN600R的骑手和乘客的分离式座 位。其他配置还包括双320毫米前制动盘径向卡钳,240毫米的后制动碟刹,50毫米倒叉和弹簧预紧力可调 悬挂。
引擎 水冷/直列四缸/DOHC/每缸4气门
缸径X行程 65.0X45.2mm
排量 600ml
压缩比 11.5:1
最大马力 60kW/11000rpm
最大扭力 55N.m/8000rpm
传动系统 往复式国际六档链条传动
供油方式 电子燃油喷射系统
制动系统 (前)双碟/每碟对向四活塞放射卡钳
(后)单碟/对向双活塞卡钳
长X宽X高 2150×840×1280mm
Link to Yan Haimei, CEO QJ Benelli announcement of ADV model plans.
So there you have it. CFMoto you lot have dropped the ball, for two years I've been asking and looking for confirmation about the rumoured CFMoto ADV based on the 650cc twin found in the CF650NK and CF650TR models. It would make a more suitable power plant than an inline four. But there ya go, Benelli have come to the party first, aside from the likes of Shineray, which aren't even a contender IMO given the X5 is a 400cc... and according to the PRC motorcycling forums has been beset with issues.
Looks like I'll be crossing the 'divide' to buy the competitors ADV, CFMoto... c'est-la-vie
YMMV
Re: Benelli QianJiang 600GT for release May 2014
I don't really get it. These companies are Chinese, but they sell a lower quality bike in their own backyard? Is this intended to deliberately alienate their domestic consumers? Where else in the world would you need ABS more than in China?
Also I'm pretty sure the cost for the non-ABS cheaper brake padded, lower grade less adjustable suspension non wheel-balanced Chinese version will cost about the same as the landed taxed version in other countries just to add a bit more insult to injury.
Also hardly anyone in their western markets wants these bikes because hardly anyone wants a Chinese bike. Not only because the bikes have a reputation as being shoddily built, but because parts are a complete pain to get for Chinese bikes in western countries, it's simply much easier dealing with a large established supply chain like Honda or Yamaha.
Qianjiang shoots self in foot.
Pretty obvious that the bike in the photos is the domestic model, check out those horrendous leg guards that don't even match with the rest of the bike! TIC addon for sure!
Have they ever had a look from front to their bike?
It looks like wearing a gas mask ..... brrrrrrr
ShuBen
Now you mention it funny but it does look like a gas mask lol
Hahahaha, who knew that we have had a bunch of would impressionists amongst our riding community... :mwink:
Still a gas mask, well if so it might be a fitting tribute to the state of the environment on the East coast of PRC -> WC.
:lol8:
5 Attachment(s)
Got up close and personal with the Benelli BJ600GSA. The general quality of components, fit and finish look to the be of high quality, braided brake lines, SHAD top box, panniers though are made from a different plastic and unfortunately use different keys... in relation to the Benelli keys, interesting design to the ignition key which is almost like a flick knife type design...
The bike in the photo (one of two received by the dealer) was still partially incomplete (e.g. mirrors not installed, battery not fitted) with packing materials still attached on different surfaces.
The seating position was neutral for my 183cm tall frame, able to flat foot the ground (32" in-seam), and an easy reach to the bars with is a one piece bar. Found the reach to the clutch lever was a stretch, and surprised to find no dial adjustment on the lever, yet the RHS brake lever does have adjustment. Weird that there is adjustment on one lever but not the other. Small screen has no adjustment.
Really nice bike, though real shame that PRC don't get the ABS option, since if there's one place in the world where ABS should be mandatory this is it IMO.
YMMV.
Attachment 15158
Attachment 15159
Attachment 15160
Attachment 15161
Attachment 15162
5 Attachment(s)
The exhaust header pipes really need some type of protection, as do the coolant hoses on the LHS. I'd suspect that a sump under-cowling might be something that the overseas Benelli factory might add to the model for the international markets, along with the ABS, better shock components etc.
Muffler collector box / catalytic converter gets in the way of any ambitions to fit an after market centre stand. I had as good look as I could underneath and beyond the aforementioned kit and could not find any form of brackets or bosses that could be employed for fitting a centre stand even if the muffler collector box / catalytic converter were to be removed.
Attachment 15163
Attachment 15164
Attachment 15165
Attachment 15166
Attachment 15167
5 Attachment(s)
Attachment 15168
Panniers locking mechanism two handles one to release from frame mounts on/off bike, while the other handle allows open/close pannier lid. Bonus is that the key can be removed so that the key is not needed for un/locking to open or close.
Attachment 15169
Attachment 15170
Attachment 15171
Attachment 15172
5 Attachment(s)
5 Attachment(s)
Though I'm kinda a interested, I'd have to say that it is more of a touring model than ADV! No spoked rims, only 150mm ground clearance, etc.
Barry
Why would you want spoked rims !!! You
Need to read how good Chinese spoked rims
Are made here in china !
Barry
Measured the ground clearance from the lowest point (crankcase) and found 190mm (19cm) clearance while bike was held vertical without rider. Measured the ground clearance of a R1150GS while on the center-stand also without rider (unfortunately using the center-stand raises the back wheel and consequently lifts the bike up thereby increasing ground clearance) and discovered that the beemer has 300mm (30cm) though several centimeters really would need to be deducted to allow for the increased height of the beemer while on the center-stand.
Perhaps the loss of 40mm (4cm) [190-150=40) difference in ground clearance quoted by Benelli is measured with rider and full luggage? Still lack of bash plate, center-stand and ABS is a pity IMO. Though as previously noted the bike will be sent to the Benelli overseas factory as parts and assembled with better components including ABS.
Measured length of front shocks and found they are 750mm, same length as the shocks on the BN600. Front fork travel total is only approximately 50mm. I'll have to double check that, but it is not a lot of travel for a bike intended as a adventure tourer. An adventure tourer needs lengthy suspension to handle anything that one might reasonably encounter on any tour.
I'd imagine that once the model has been released abroad and if sales are favourable an after market segment may develop where other accessories and add-on's can be sourced. If this is the case, a center-stand would be my number one purchase.
3 Attachment(s)
Couple of extra photos...
Attachment 15546
Instruments...
Attachment 15623
Attachment 15547
view from petrol tank
4 Attachment(s)
5 Attachment(s)
bikerdoc
I see only specs and pictures.
Did anybody already tested the bike?
I'm really excited to know the truth
I for one is also waiting for a bike report
I did hear the Doc was very close to buying
one but I think he purchessed a imported bike
which is a shame not for the purchessed
Of the imported bike but he would of done
a very good report on the GT based on his
other bike reports he has posted on MCM
before !
A review of a model for the Indian market, praise is high...
http://www.motorbeam.com/2014/11/bik...t-ride-review/
^ a few points the writer/tester didn't get quite right. ABS will be an option for the 600GT that will be assembled outside PRC. Two assembly/manufacturing plants will be putting the 600GT together, one in PRC in Taizhou, where the model is manufactured (non-ABS 600GT) and the other is located outside PRC which will receive the engine, frame etc (but then provide and fit the 600GT with better suspension, brake components and ABS) for the 600GT to be sold in Europe etc. I attempted to try to place an order with Qjiang to prepay for one of the overseas assembled and upgraded parts models, and have it imported back into PRC, but Qjiang weren't interested in that idea. At that time (earlier this year) Qjiang only offer the 600GT without ABS and better quality components. TIC. Perhaps the attitude might change with CFMoto models being sold with ABS locally. Let's hope so 'cause if there's any one place in the world where ABS is needed it's TIC the LFZ.
The 600GT is not really an Italian beast, it is built by Qjiang, in Taizhou, Zhejiang province, PRC!
The 600GT only made it to market this year, last year (2013) a prototype was at the EIMCA show.
The tester/writer does not indicate how long or what distance nor surfaces the 600GT was ridden for the purposes of the test - which IMO is relevant. Several friends here in PRC that have the 600i (BN600 or BJ600) have had issues with them and most have sold them. In one of the riding circles there was/is approx half a dozen BJ600's... most have had issues e.g. overheating, fuel pump failures (which is located inside the petrol tank) and so on.
A local riding friend had one of the first 600GT models since April this year, and racked up quite a number of kilometres. After taking a Kawasaki Versys KLE650 for a ride on a trip elsewhere in Asia, he promptly sold the 600GT. He is now waiting for the release of the KLE650 here in PRC as he absolutely luv'd the ride. His comments about the 600GT were it was heavy and a slug to move round and he just didn't realise just how much so until he'd ridden the 650 Versys. He didn't care that when he sold the 600GT that he'd be without a ride until Apr/May '15 when the KLE650 is released post CCC.
YMMV.
I for one will wait for the 2015 new Versys to come over from Thailand for people who are looking for a good imported ADV bike then I think the Versys ticks 90% of the boxs IMO and at 83K Rmb this could be the way to go , can't wait for CF to make the talked about new ADV MT. And I am sure the Versys will sell very well in China .
Sorry Doc to point out the tester/ writer did say 1/2day and 300km covered to make this report ,
IMO still not a great distance to cover to be fair
These days reviews by professional journalists do not have the same accuracy or integrity than they once did. Sadly companies do pay for positive reviews these days, happens in many industries.
Hi Guys, I'm from India. Presently ride a KTM duke 390. Please don't trust Motorbeam reviews, because they're not worth. PowerDrift and Overdrive(Odmag)'s youtube channel and blogs are good and realistic. Benelli have created a lot of noise in India and the bn300 and 600i naked is selling like hotcakes. Even GT the tourer one got good response. I'm planning for the GT after waiting for few month; mainly to see the reviews and the parts/service cost. But as I read through the forum it seems if you fill the 27ltr tank to full the GT becomes very much Front/top heavy bike on corners. Is it true? I've taken a test ride the motor is very smooth, clutch is light and gerabox is butter smooth. It costs almost 10500-11000$ on road(Inclusive of insurance and other taxes) in India without the Panniers+luggage mount(700$ more for these!). The service interval is like this:
1st service at 1000kms - oil change(3.5Ltrs Motul7100 10W50+oil filter change)
After that every service at 4000KMs interval. Isn't it too much? May be they're doing this to make money?
Indian DSK group tied up with Benelli for selling and service the bike in India. DSK also sales Hyosung here and provides very pathetic experience regarding service and parts cost. I was riding a Hyosung GT650 naked model before and was forced to sell it very less price due to the problems with the bike. God knows what they'll do with Benelli.
