how to check and change gearbox oil and engine oil Loncin 250cc
Hi i'm new here and i have a Loncin 250cc motor and i don't know how to change or check the engine oil,how much oil should be in there and how can i check the gearbox oil and where is the filler plug, how much oil should be in there one other thing i'm curious to know about i have a little hole on my gearbox cover and i think all the gearbox oil leaked out and i need to know what type of oil and if i can use havoline automatic transmission fluid and how much i need Thanks :icon10:
01-20-2015, 12:37 AM
humanbeing
Re: how to check and change gearbox oil and engine oil Loncin 250cc
Engine oil is the gearbox oil
If you loose oil its engine oil
The gearbox uses the oil from the engine!
Sounds dangerous to me if lost any oil
01-20-2015, 03:25 PM
1999
3 Attachment(s)
this is the engine that i have,but i was wondering about the dipstick and the little glass level check thing,which is for the gearbox and which is for the engine it self and were can i put more oil for the gearbox is it the little screw/plug right on top of the gearbox cover, and am i right that i can put more oil for the engine it self thru the dipstick hole and which bolt is it to drain the gearbox and/or the engine the one marked green or the one marked red
The green one has a small screen filter and spring behind it
The red is also a drain or maybe the main drain plug
Drain from both or Chinese monkey does it from the green only
01-21-2015, 04:46 AM
NZBrakelathes
Mate your a bit lost! Engine oil is also gear box oil
It's all in one like 99% of motorbikes I know of
1 litre of oil is needed empty to full
Use the glass and dipstick to check the level.
01-21-2015, 06:33 AM
humanbeing
know what type of oil ...
The cheap 15w40 for diesel ( non energy conservation/ higher ZDDP ) is a safe bet . If u believes those :bs: BUY the "proper" bike oil that meets JASO MA. http://vfrworld.com/tex_vfr/tech/oil.htm
Skip 08:30- 28:40 in "normal" oil change
01-21-2015, 11:45 AM
1999
So if i'm getting it right when i put oil thru the dipstick hole then i am filling the engine and the gearbox,but i get oil reading on the dipstick but i don't see any oil reading on the glass oil check and i have a small hole on the bottom of my gearbox cover, but what does the plug/screw on the top of the gearbox cover do
01-21-2015, 12:48 PM
beniamin82
Better fill oil and check it on the glas window. The dipstic maybe (often) from other motorcycle model.
The top plug/screw is to see marks they you need to adjust the valve clearences.
And the side with the plug on the top is not gearbox side it is dynamo/magneto side. Often there is no oil.
01-21-2015, 04:34 PM
NZBrakelathes
Oh boy your a real beginner
Often the glass window is dirty or oil is just a little full and can't see the air bubble.
Check dipstick or drain the oil and only put in 0.9 litres to check dipstick and glass - it should be near correct or just slightly low
01-21-2015, 04:57 PM
1999
Ok thanks everyone i am just really new to these engines i know yamaha suzuki kawasaki and honda very well but this one is a bit diffrent in looks but now i know that there is a very little diffrent between them
01-22-2015, 11:44 AM
humanbeing
Just a CG125 on steroid. Plenty info on 'net about this family ...
