CFmoto 650NK Oil pressure light
Hi all, hope this is the right place to post..
My oil pressure light comes on after the bike is fully heated up. It only comes on when at idle rpm tho.
Could this be from wrong oil ? broken sensor ?
I live in australia and im not sure what oil was put in from the last owner i'll be changing it asap. Also i'll be taking the airbox off and running pod filters as it runs hot as hell being right behind the radiator lol ?
Any suggestions are appreciated
Re: CFmoto 650NK Oil pressure light
Mate probably there is just shitty oil and the wrong amount of it in there. Do a hot oil and filter change and put the right amount of good oil in her and you should be sweet.
I agree with NZb I doubt pod filters will help you, they'll just screw up the fuelling. Bike doesn't really run hot it's just a paranoid thermostat that comes on really easily, but check the coolant level too.
Roger that guys. I'll change the oil and oil filter asap, if that doesn't fix it ill check the pressure properly. What oil would you recommend being in australia ? 20-50 ?
Also the oil levels seem to be fine, checked when bike was stood upright, between both the markers.
I have a .pdf manual. recomended is 15w40 but also states this on the same page.
Although 15W-40 engine oil is the recommended oil for most conditions, the oil viscosity may need
to be changed to accommodate atmospheric condition in your riding area.
Attachment 17171
I'm in South aus. I mean it does get quite hot but i agree with you probably not hot enough :eekers:
I use 20W50 for the Chinese summer 20-40c and I never have a problem with oil pressure on the same bike, most likely it's just oil level.
Ok thanks for your time guys. I'll report back when this is solved. :)
CrabMan
Hope it will be resolved soon.
Late reply but solved it with some thicker oil. loves it now and got a nice yoshi pipe on it too :)
CrabMan
Good to know everything is a ok now. :scooter:
CrabMan
I have the same problem. what oil did you buy?
