Kinlon motard carb default settings
Hi all.
I bought a kinlon jl200sm
A while ago for a bargain. The previous owner had maybe kick started it while it was running which spat little gear peaces through the box and seized a Bering, which broke apart and spat out part of the gearbox shift.
Good news I fixed it and it has identical internals as the xr200. I even bought xr200 bits to fix it.
Problem is it doesn't want to run. I can get it to run with some coaxing, something high octaine down the air filter but it just doesn't want to idle. Once I eventually get it warm it will just run out high idle.
I've tried moving the air diaphram with the circlip a notch and have tried the mixture too.
Any thoughts?
Images to follow when can figure out hosting
Re: Kinlon motard carb default settings
"Humanbeing", it looks that this "Kinlon", although with pushrod engine, is fitted with CV carb.
Zorge
国II (euro 2) JL200GY-2 are fitted w/ Walbro PZ30 http://www.mep.gov.cn/image20010518/6060.pdf in domestic market. Don't know what's in exported version yet.
humanbeing
It isn't this one. I took it apart and cleaned the carb after finding about a large amount of water in the tank. Carb had some gum like crap in it.
I'm pretty sure I put it together exactly how it was counting turns on screws etc.
MJH
That's it!,
what's it called? I just wanted to get it running if it's a clone of something I'll start with those settings.
I've read other people having trouble with idling because of lean mixture because of emission control . I just wanted to start from scratch.
I do not think the bike sold in AU have that carburetor, least the images on the Kinlon site in Australia don’t they look to have a slide type. http://www.kinlon.com.au/
http://www.kinlon.com.au/wp-content/..._2-150x150.jpg
murrayh
That's it!,
That is Chinese made "Teikei". We recently had a guy with the same carb - http://www.mychinamoto.com/forums/sh...ll=1#post78817
Basically, every CV carb tuning guide will be good for you to know where to start, and what and how to get that.
Zorge
Awesome just what I was looking for. Thanks all
Does anyone know how well these bikes go.? I just got back from a trip on my Cd250u and it struggles a bit open road speeds. Are these any better?
I had always planed to mod the motard a bit figuring it was made with the smallest part at manufacture.
