What do you all use to lift the front of CF-650TR
What do you all use to lift the front of CF-650TR, do you use a paddock stand on the forks or do you use one that lifts the head stock or a bike lift?.
If a lift, what type and where would you put it to lift the bike safely, we have a catalytic converter underneath on UK model.
If a paddock stand on head stock is there a another make/model of peg that can be used, it is unlikely we would have CF-650TR fitting here in UK, I know there is a rubber bung in the bottom of fork tube.
4 Attachment(s)
Re: What do you all use to lift the front of CF-650TR
Hi Phil
Just Changed the tyres front and back for the trip back home on the TR-G and I use paddock stands front and back.
Here is the set up with my old TR, now with your bike having the short side stands it makes it harder to get the backup first by yourself, so best IMO to get someone to hold the back at 90 Deg and then locate the back paddock stand under the side bobbin.
I always if you are taking the wheels off the bike then crack the nuts loose when the bike is on the ground first.
Attachment 18596
Attachment 18597
Attachment 18598
Attachment 18599
I use a similar one to his ^^ that I found on Taobao but it is completely adjustable width wise and can be used on the front or back. It can be used on tiny or big bikes and it was only 200rmb on taobao.
prince666
Hi Phil
Attachment 18596
Attachment 18597
Attachment 18598
Attachment 18599
Yes that is what I have been looking at getting, I carry a block of would to use when filling tank, so could put that under side stand before attempting to lift it on to paddock stand.
What do people use to do a re-pack of headstock bearings.
I noticed the engine on your old TR is painted silver on ours they are black see pic, pic is not mine but is identical, not yet taken a decent photo of mine.Attachment 18610
BigPhil
Attachment 18610
Happens a lot in China run out of sliver then just use black next week waiting to see a yellow engine lol
prince666
you must admit though, it looks a very classy bike and so smooth at motorway speeds, it is going to be very interesting to see what bits if any fall off the G's on "TheLongWayHome" ride or if they break down, they shouldn't of course unless thrashed.
BigPhil
I think the only bits that will failing of will be "ME" lol
I tried to do a route in Google like the one on the blog but it cannot be calculated, little bit hard to see the towns on the route on little bit of a map.
When you setting off, set a date yet.
BigPhil
Just about to update the blog phil give me 30 mins ok
Attachment 18612Picture of Bullet
Hi Phil
My engine casing is silver, perhaps with yours being a later model, you get black !! :-)
linuxyeti
Hi Phil
Still a beautiful looking bike no matter what the colour and if the G model was available I would be riding one.
