Any one else got much experience with the mikilon m96 -125sb?
I've been looking for a decent manual, tips for setting idle etc etc
It appears to have a Loncin 170MM engine. I believe it's a clone of the Yamaha YZF250 or YZ250 of around year 2000, so you would be better off looking for a manual for the Yamaha than for the Loncin. The Chinese are not too hot on issuing technical info.
There are a couple of yamaha YZ manuals in this amazing list of downloads from Carl Salter:
http://www.carlsalter.com/motorcycle-manuals.asp
thats forchetto, thought as much
here's a pic of the carb I'm trying to get details for
the first photo shows a screw thats held by 2 locking nuts (idle screw?), and the second photo shows a screw in the main body. I'm guessing that the second one is the mixture screw? does this sound correct
ps here's a few build pics as well
Andy,
The second screw is almost definitely (let just say definitely) the air/fuel mixture adjustment screw. As far as the first screw, I never seen an idle screw that was locked down by two nuts and not adjustable by hand.
If you have the type of carb that raises a needle/plunger assembly when you apply the throttle, then the idle speed set screw is usually on the upper barrel which houses the needle/plunger unit, usually sticking out at a 90 degree angle.
If you have a CV type carb, I think the idle adjustment screw is usually attached to a small frame which adjusts the resting position of the throttle cam. These screws usually sit in line with the cable.
Either way, I don't believe I've ever seen an idle screw locked down by two nuts. Do you have any other pictures of the carb?
C
here's a few more pics carl
It's an odd carb that. The double nut-locked thing is part of the accelerator pump mechanism. That's that thing hanging off the bottom of the float chamber. Probably adjusts the stroke of the pump or the timing.
Another oddity is the idle mixture screw. Contrary to most other slide carbs, this one is situated on the engine side of the carb rather than the air filter side. This means that it controls fuel flow rather than air flow to the idle circuit and has to be turned anti-clockwise to richen and clockwise to lean the mixture. Need a shortened screwdriver for that. There's not much clearance there.
The idle speed screw has to be somewhere close to the black "wheel" thing that has the throttle cable on picture 4 on the second set. It's probably knurled for hand adjustment.
will keep on digging, its a keihin 28mm carb but can't seem to find the right manual :confused1:
I think they're called PZ. They come with or without an accelerator pump. This option is often used on ATV's to improve the response at low revs.
The idle screw is just behind that black wheel thing, on the body of the carb and can be accesed through the wheel.
The make is DENI made by ZHANJIANG DENI CARBURETOR CO., LTD. They're part of the Japanese KEIHIN group, and the most common model is the PZ27 (27 mm).
Sometimes people call them DEKNI because the logo has a stylised "K" in the middle.
http://www.cpp.hk/en/images/zhanjian...logo_dekni.gif
The "K" is part of the KEIHIN logo, (the "dot" on the "I"):
http://www.ecommunity.com/healthprom...eihin_logo.jpg
Google "DENI PZ27" and you get lots of references, but the "pumper" model with accelerator pump is hard to find. This is a picture of the PZ27 without the pump mechanism. You can see the mixture screw right in front of you and if you look to the left side you can see the idle speed screw, the one with a spring on it:
http://www.chinapartscanada.com/shop...PZ27_carb4.jpg
thanks guys worked it out in the end it was under the black plastic cam. its recessed and not easy to find :icon10:
Andy,
:eekers: Glad you found the idle set screw although that's one helluva inconvenient place to put it! Normally those things are easy to set by hand or a flat head screwdriver. You see that little doughnut shaped metal bump on the right side of the slider housing? Normally there's a screw in that location which raises the slide up and down as needed and this adjusts the throttle (see the attached picture below). Not really sure how yours actually works though but it's good that now we all know!
I think most of the slide type carbs I ever used and/or serviced in China had the mixture screw towards the engine. You're right that this one doesn't give you much space to work with but at least the screw head itself is exposed. Some of them were recessed and that made it damn near impossible to even see where the screwdriver was going even if you could manage to get it in there. Basically, any time you wanted to play with the mixture, you had to either use a tiny driver and get burned or remove the carb. :taz:
:icon10:
I'm looking for the same thing. So far I'm really happy with the bike but will need to start service soon and need info and a source of spares. Did you find anythinge useful?
hey there guys and girls ,
i have just brought myself a Mikilon M96 125-SB SuperMoto and i have had a fare few problems to say the least but the most major problem i am having is setting the air/fuel mixture screw correctly .
I was wondering if anyone happens to know the default setting for this ,eg how many turns out to get it sweet ?
Hi,
I checked its factory setting at 2.5 turns when I got my bike, but cannot guarantee that this is the best setting. Seems OK and bike is pulling alright.
might need to do some trial and see how it goes.
Hey guys. I really don't think the "factory" setting on the carbs is anything more than consistently putting the screw half way through it's turning range fora ll produced carbs. Carbs are not usually produced by the manufacturers and there's a great question as to whether or not the manufs do any ajustment to them before shipping.
Best thing is to tune it for your bike and riding environment.
i have recently bought a mikilon m96 and am having some problems when ticking over or reving high the front end i.e the forks and front wheel vibrate like mad and i am having problems with the ignition sometimes it works sometimes it doesnt i have to knock it off and on all the time please help as its getting dangerous ??????
Hi guys, I'm french, and I've bought a mikilon m96 ....
(There is not much of these bike in france ...)
You seem to know how to tune this carb. Can you explains a little more about this ???
Actually the engine had a lack of power : I can't engage the 3rd speed, nor accelerate with the second (when accelerate, the engine fall down ....) => I think it's a carb problem ? Isn't it ?
Thx
hi guys, just got one of these mikilon M96-125 SB's any idea where i can get spare parts from? cant find any anywhere. thanks
