atv front end setup ????workshop manual ???
:confused1: what are the basic settings for front end geometry of a quad ?
the front end sqeels like a pig around even the slowest road corners ..with or without a back wheel off the ground. i have measured the underside of the frame and all wheel mounts seem to be square, rear axle alined etc .. just dont know what the (tracking ) tow in or out should be also caster camber would be good
WHY ARE THERE NO WORKSHOP BOOKS AVAILABLE FOR CHINA QUADS ???
it lets a reasonable product down.Attachment 5433
Re: atv front end setup ????workshop manual ???
i had some time free so i stripped the front end and checked everything was ok. i set the tracking to parallel and it still looked wrong. i then had a friend sit on the quad and re set the tracking to parallel.. it is now much better around corners with no squeeling. i will watch for uneven tire wear and adjust to suit
