3 Attachment(s)
Shineray XY250GY-2 MX carby clean and New Twin Air filter
So i pulled me carby apart and gave it a clean. I was on a websit called nightriders.com reading up about the tk mv 30 cv carbys when i came across this mod.
So i bit the bullet and did it.
Its a hole you drill out a little bigger on the slide with the needle and diaphram.
I used a 3mm drill bit.
Drill the hole next to the needles hole.
Attachment 18814
This is the piece you be modding.
The hole is for vacume only and it give more mid range.
I finnished this off with a twin air air filter.
Its a ktm direct fit.
Attachment 18815
Attachment 18816
Now its back together and took it for a lap around the block and it does feel i woke something up.
Re: Shineray XY250GY-2 MX carby clean and New Twin Air filter
This is the old filter that came out. Its got ipone filter oil on it but its probly a little restrictive when it comes to air flow.
Attachment 18817
Attachment 18818
Looks the part now.
Oh i will do a dyno run soon and up load it to my you tube channel.
There will be more details on this mod when i replace the jets
