3 Attachment(s)
Shineray XY250GY-2 MX Exhaust rebuild.
Ive never heard of this until recently. But its maintenance and good value for money for HP/KW.
There is packing inside of the exhaust that gets old and needs to be replaced.
You can buy it from Ebay or a motorcycle store for around $20.00 herw in Australia.
I got the normal one cause of an exhaust upgrade i will be doing. But if you like standard exhaust get the FMF packing cause it aperently increases HP?.
Attachment 18747
Remove your exhaust and make sure its cold.
Drill rivets out.
Attachment 18748
Make sute you take note on the way the exhaust comes apart.
Attachment 18749
Re: Shineray XY250GY-2 MX Exhaust rebuild.
Wear gloves its messy.
Attachment 18750
Unwrap the exhaust wrapping from the exhaust chamber.
Mine was held together with 2 pieces of wire.
Attachment 18754
Clean the inside of the outer housing at this stage i figured i would purchess an after market exhaust after i do my first dyno run as a standard bike.
I painted mine with heat proof paint dunno why.
Attachment 18777
The build quality is just good looks but inside is no performance exhaust quality it would make good power with an exhaust up grade.
Attachment 18778
Now wrap your wrapping arond inner tube not too tight and not to loose. You can spread the wrapping if its a little too short. I used some aluminum mig welding wire to hold it together.
Attachment 18779
Now stuff it into the outer tube using aflat head and force it slips in easy if done right.
Attachment 18780
Put your exhaust pipe and end cap on and rivet it back together
Attachment 18781
All done.
Attachment 18782
