4 Attachment(s)
2014 Suzuki V-Strom 1000 First Look
Motorcycle USA 2014 Suzuki V Strom 1000 first look article...
Monday 23 Sept 2013.
Attachment 13820
The Suzuki V-Strom 1000 will get its long anticipated redesign update for the 2014 model year.
Suzuki teased the long-awaited overhaul when it unveiled the concept V-Strom 1000 during last year’s Intermot show. Big changes were promised during the reveal and Suzuki has come through on its word, announcing a production V-Strom 1000 for 2014 that boasts a slew of upgrades to challenge for a share of the ever-growing adventure-touring segment.
The 2014 V-Strom 1000 gets more oomph than its predecessor with a larger, 1037cc V-Twin that has been bored-out by 2mm. Its cylinders, cylinder heads, pistons, piston rings, connecting rods, crankshaft, clutch assembly and radiator were all redesigned to help improve performance in the low- to mid-range. A redesigned flywheel is said to have “greater inertial weight” allowing for increased control at the low-end of the powerband. The Suzuki Dual Throttle Valve system is claimed to improve combustion efficiency and an updated engine control unit works to optimize ignition and fuel injection. A 32-bit engine control module aids in more precise engine management, improving fuel economy and linear throttle response.
Eiji Sasaki, Suzuki’s Engine Experiment Engineer, offered these remarks about the updated V-Twin: “With their unique low rpm rumble and strong high rpm, V-Twins are very unique. However, they can be tricky to ride at low speeds due to their increased combustion shock.
Attachment 13822
“Therefore, our development theme was to make it smoother at low-to-mid range rpm for touring while maintaining the free-revving nature at high rpm. As the engine was originally designed as a sport bike engine, it naturally has a free-revving character at high rpm. So our focus was on how to develop the engine character to make it easier to control at low-to-mid range which the rider will use on a regular daily basis.
“We have refined the fuel injection settings, increased inertia, added twin spark plugs, and redesigned the magneto. In fact, nearly all internal parts have been extensively redesigned; it will feel like a totally new engine to anyone familiar with the previous model.”
Attachment 13821
The V-Strom 1000’s transmission is updated too, with gear ratios adjusted for the new engine specs. The new ‘Strom also utilizes the Suzuki Clutch Assist system, which is said to work in two ways; first as a slipper clutch to help smooth out downshifts and also as an assist clutch to help make lever pull easier.
Spent gasses flow out of a newly fabricated single muffler and the Suzuki Exhaust Tuning system makes use of a butterfly valve in the pipe to optimize exhaust pressure and help boost torque at low revs while also enhancing throttle response. The 2014 ‘Strom 1000 has an updated catalyzer and O2 sensor to meet Euro 3 emission standards.
“Developing the exhaust pipe was the most difficult part,” said Sasaki. “In a V-Twin engine layout, the most difficult thing is designing the length and layout of exhaust pipes. To increase low-to-mid range torque, a longer exhaust pipe is better. However, there is not much space left when you consider the rear suspension layout and ground clearance.
“Therefore, the exhaust pipe has a very complicated shape. We have also changed from a double-sided to single-sided exhaust silencer to minimize the influence on handling.”
Also new on the 2014 V-Strom 1000 is Suzuki’s first traction control system. The Suzuki Advanced Traction Control system monitors front and rear wheel speeds, has a throttle position sensor, crank position sensor and gear position sensor to help regulate engine output by managing ignition timing and air delivery. There are two modes available in the TC system, with Mode 1 allowing modest wheel spin and Mode 2 allowing little-to-no wheel spin. Riders will be able to shut off the TC system completely as well.
Attachment 13823
Suzuki offers fully adjustable, gold-anodized 43mm inverted forks for 2014. The rear shock is preload adjustable via an easily accessed dial. Radial-mount four-piston Tokico monobloc calipers grab a 310mm disc out front while a singl- piston caliper grips a 260mm disc out back. ABS comes standard on the 2014 V-Strom 1000.
Re: 2014 Suzuki V-Strom 1000 First Look
Maybe send the link to CFmoto head designer so he can read how to build a good bike....
The Suzuki TL1000S was introduced by Suzuki in 1997 and was produced until 2001 and is frequently referred to as the TLS or Suzuki TLS. It is notable for the V-twin engine which is still used in Suzuki's modern SV1000 and V-Strom 1000 motorcycles.(wiki) This bike has been produced and "developed" for 16 years so how will your CF be after 16 years . At least give them a chance... I remember those TL's when they first arrived , they had overheating problems and some kind of strange rotary rear shock. They were considered a poor mans ducati they never sold well and people who owned one were mocked and ridiculed. Sound familiar?
