Re: My blog of a Pulse Adreneline 250...
sorry I might add ,the insoles are separate items,,,so 3 circuits in all,,,sorry for the hijack Ghost
On second thoughts that regulator I linked you is a little underpowered, it can only output 2 amps so you would probably need 2 or 3 of them. If all your devices can run on 5 volts this one should be able to run everything all at once, it can output up to 5 amps but the voltage is fixed at 5 volts.
http://www.ebay.co.uk/itm/12V-24V-DC...item5657179b03
Do you know what each device draws and the voltages they run at? It may say in the manuals.
Hi
Well I eventually got my hands on a shiny new Adrenaline 250.
Had a 90 odd mile ride back from the dealers and she was definitely less jumpy at the end of the ride.
Few issues, didn't,t notice till I got home but they gave me her without road tax or the toolkit.
The battery terminals were loose so had to tighten them and mirrors started flapping around at dual carriageway speeds (not good without a tool kit).
First service is at 300km which isn't ideal but there are closer dealers than the one I bought from.
So other than a couple of niggly things very happy.
Will keep you posted.
Regards
Ian
