Re: Knobby or Enduro Tires?
No tyres will help much when it is both wet and oily in the circumstances you mention! There is a lot to consider - the ground you are covering, i.e. how much off-road and trials do you intend, how much asphalt, is the asphalt dusty and rutted , how much gravel or loose top? Then apart from knobbies or semis, there is soft and medium compound to consider and you can mix that front and rear. Need to know more about how and where you will use the bike.
Others may disagree but I find tyres and setup more critical for steering than just stopping the thing! Responsive and mannered steering is what avoids/solves most problems.
Remember also, tyre pressure being increased/decreased can compensate for a lot of road factors so why not take it as it is (assuming the reputable manufacturers have sense enough to set it up well as a compromise machine), try it for a while, drop the pressure off-road and use as rated on road?
I am using quite aggressive knobbies compared to road tyres on my dual-sport and it seems to go all over the place whatever I do and wherever I do it, so the rider skills or lack of make a big difference too lol ... but seriously it is safe enough on knobbies and handles OK and stops well enough so I don't feel the need to change them yet. If I was leaning right over and flogging it through bends and ninety percent on smooth roads I would reconsider that.
Spring setup for your weight and where you seat on the machine also affect stopping, as does braking technique. Take it as is and get to know the machine, unless the suppliers offer a no-cost tyre change choice at purchase, then we need to know more info to advise you.
Thanks. Thats what i did. I just put a deposit on a revelutionary (red) XY200GY-7. i should be riding in 20 days.
congrats on the purchase! now for the long wait....
Usually the tires that come stock on Chinese bikes are not very good. Sometimes they have a coating on them which will make them VERY slick (even in relatively dry surfaces) until it been worn off so don't start practicing your emergency braking too soon.
There are a couple tire threads on MCM about what's available in China. If you're going to do any riding outside of the city, then I'd say go with some dual sport type tires(not moto-cross) because you will hit bad roads eventually. Regarding water, oil and diesel on the roads, the only thing you can do about that is not speed, don't grab the brakes and keep the bike as upright as possible.
Good luck on your new purchase and be sure to take lots of pics! The red version of the GY7 should be sweet!
Paz,
