Re: Manual for ZongShen CG125 aka 200-250 Push Rod Motor
hi i was wondering if anybody can help me i have a ZS167FMM zongshen 250cc 4 stroke dirtbike i recently tried rebuiding the top end but i dont have a manual or anything to help me .....is there any won out there with a pdf or a manual that i can print .....i replaced rings ..put it back together ...had almost 120 compression then some how lost it and all i got is 30 psi now ....NEED HELP PLEASE
Rings ONLY often = useless. It needs the whole kit. Refer to Honda CG125 manual for "how" when necessary.
Someone's bike that are powered by Lifan CG250 (167FMM) . Google translate the following u will get the idea
http://www.motoyes.cn/bbs/forum.php?...authorid=96035 Disaster caused by "pal" putting no name oil. Owner uses Castrol Power 1
http://www.motoyes.cn/bbs/forum.php?...authorid=96035 Diesel motor (CD40) oil experiment.
http://www.motoyes.cn/bbs/forum.php?...authorid=96035 Change 6 speed + whole "kit" @ 40k km
http://www.motoyes.cn/bbs/forum.php?...authorid=96035 Redlining the rev
http://www.motoyes.cn/bbs/forum.php?...&goto=lastpost That guy blown a CG200 piston after trimmed 1mm
humanbeing
Dear Perkins,
On the hunch that you are not a reader of Chinese, you can get help with these motoyes.net pages that humanbeing sent by using the Google Chrome browser to browse them. Chrome will sense that they are in Chinese, and offer to translate the whole page into about 97 different languages, including English. OK, it's machine translation so take it with a grain of salt, but it should be enough for you to understand the posts. If you have any questions, don't hesitate to post them.
Unless you are in Ontario, California, I'm guessing that this rebuild is a winter cabin fever project to do in your (hopefully heated) garage. It's a great chance to help other owners of that engine to understand the ins and outs of this kind of top-end rebuild, so please feel free to post as much as you can or like about the process! Turn this into a tutorial for others. Pictures of course are very welcome (and, in fact, technically your bike does not exist in MCM unless you post pix; them's the rules!).
And welcome to MCM!
thanks to both of you ......yes this is a winter job ...its dismantled in my basement workshop ....i think i have a bad valve (exhaust side )
i can read it in google chrome but for some reason i cant print it
VALVE LASH....do any of you know the correct settings for the valves...i have it set up for .006 thou on eaxh valve between the rocker arm and top of valve...i havent started it or even put it back in bike yet just want to make sure if i had it right .......seems to have good compression but hard to turn over with it on a work bench and not in the bike
Re: Full US Manual for CG125 aka 200-250 Push Rod Motor
i have recently got my hands on a Zongshen 167fmm quad atv . Would you have a service manual for this bike on your cd if so is there any chance that i can get a copy of it
Gerry
hi forchetto
I am chasing a manual for a 167ffm Zongshen quad atv do you have manual or where I can get one from
I am using piaggio robinson byq 125-8. Can you please provide owner manual. At least provide the following information:
1 Correct tyre pressure
2. Engine oil requirement
3. Suspension adjustment
