Indicator ONLY work when steering left or right PULSE ADRENALINE
Hi, I have a Pulse Adrenaline 125.
The front indicators only work when i steer left or right full lock.
If the bike faces forward then none of the front indicators work.
On the "dashboard" the indicator light flashes properly when i indicate so the problem must be with the wires but what could it be?
Re: Indicator ONLY work when steering left or right PULSE ADRENALINE
thomas1420
...so the problem must be with the wires but what could it be?
So you are right.
What could be the problem with wires?
Only two issues: some wires do not have contact, but they should, or some wires have contact, but they should not. :icon10:
Оn my bike, steering limiter "bitten" a couple of wires and left me without electric starter. Everything else worked OK.
In addition of loose contacts, check the "state of affair" around steering stems.
Ive ordered the battery tester so maybe on Wednesday i will see which wires dont have contact when the bike is straight facing forward.
Thanks guys for now :)
